Air temp sensor
Old Jun 2, 2008 | 08:30 AM
lorenc's Avatar
lorenc
Default RE: Air temp sensor
As it turns out, I replaced my sensor with one off my friends bike. The accuracy was off just as much as mine so,,, that means I have need of a different gauge. Anybody want to get rid of one?
Old Jun 2, 2008 | 08:34 AM
Beemervet's Avatar
Beemervet
Check your email................
Old Jun 2, 2008 | 08:41 AM
FLHT's Avatar
FLHT
ORIGINAL: lorenc
It's not your sensor and its not your gauge. If you want it to read halfway accurate you need to move the sensor down out of the fairing and put it between the forks.
Old Jun 2, 2008 | 08:44 AM
lorenc's Avatar
lorenc
I did move the sensor down in the forks. Did that last fall.
Thanks
Old Jun 2, 2008 | 08:47 AM
FLHT's Avatar
FLHT
Sorry man, There I go assuming again How far off are you reading?
Old Jun 2, 2008 | 08:54 AM
lorenc's Avatar
lorenc
About20 degrees yeaterday. 82 degree day and it showed around 100
Old Jun 2, 2008 | 08:59 AM
FLHT's Avatar
FLHT
Yeah that is quite a bit. Mine is usually within 3 or 4 degrees. Did you look in the parts for shipping area of the forum?
Old Jun 2, 2008 | 09:06 AM
lorenc's Avatar
lorenc
Yep, Now I did.
Thanks
Old Jun 2, 2008 | 10:07 AM
Danowert's Avatar
Danowert
Interesting that moving the sensor outside the fairing didn't help improve the accuracy. My dealer here in PA stated that it was more of a gimmick and a cheap way to fill a whole. He said that it goes back to the early 60's when Caddy and Lincolns had the temp gauge in the dash. My gauge is at least 20 degrees off, but I have not moved mine yet.
Rees107
Jul 2, 2022 09:14 PM
2009blackpearle
Engine Mechanical Topics
May 29, 2018 09:40 AM
sunderhill
2014-2024 Touring Models
11
Jun 29, 2016 10:05 PM
hawgwildterry
Sep 27, 2015 02:18 PM
rodney123456
Jan 7, 2012 04:50 PM
