buffing out chrome
Old May 13, 2008 | 12:54 PM
honestbob's Avatar
honestbob
Default RE: buffing out chrome
just remember you are not buffing a scratch or a pit out you are removing the surronding metal down to the level of the scratch or pit. and as thin as the chrome layer is it doesn't take a lot to ruin the finish.
Old May 13, 2008 | 01:14 PM
Chicago Spike's Avatar
Chicago Spike
Once chrome is scratched, it's scratched. The only way to fix is rechroming. Do not use a polish or rubbing compound, these will only make the chrome look dull or cloudy because most polishes have abrasives in them. If you are trying to remove the bluing, get a product that says that is what it does, like "Blue Away"
Old May 13, 2008 | 01:19 PM
quackhead's Avatar
quackhead
i usereal finesteel wool on my chrome if there is any surface rust. then use never dull or a chrome polish on it.
Old May 13, 2008 | 01:53 PM
08SweetGlide's Avatar
08SweetGlide
I use the Zaino Z2 on mine same that I use on the paint its a polish with no abrasive in it the Z5 has some abrasive in it best stuff I found.
Old May 13, 2008 | 02:05 PM
CTB's Avatar
CTB
I've never done this kind of thing before but can you clean chrome exhaust pipes using a buffing wheel on a bench grinder? At my local hardware store you can also get a "red" jewlers paste for polishing. Would this work or scratch the *&^^&$# out of the pipes?
I guess this is why my wife says she don't understand me - actually I wasn't asking about removing scratches - I was worried if the buffing process (on a bench grinder) would "cause" scratches. But I think after going through some of the comments here and visiting the recommended web sites the answer really depends on the type of compound you use? What about the buffing wheel and rpm
Old May 13, 2008 | 03:01 PM
wuznme's Avatar
wuznme
Magix Mix Metal Polish and some good cotton towels.
Old May 13, 2008 | 03:09 PM
frog13's Avatar
frog13
Cheap old Turtle Wax Chrome Polish and Microfiber cloth!!!! On my shovelhead, I have some pitting on my cam cover, but if I keep it clean and polished, it is barely noticeable.
Old May 13, 2008 | 03:37 PM
SG 1's Avatar
SG 1
ORIGINAL: CTB
Your question seemed clear enough to me. Thefew times I've tried to clean chrome with any thing other than chrome polish I have scratched it.
enginesludge
General Topics/Tech Tips
Dec 7, 2014 12:30 PM
jimmorningstar
Jun 20, 2010 09:01 AM
Tinmanpope
Oct 20, 2009 06:57 AM
ydnob
Mar 1, 2009 10:19 AM
chop09
Detailing
Mar 6, 2007 04:09 PM
