something is slipping?
Old May 15, 2008 | 06:31 AM
OnTheFence's Avatar
OnTheFence
Default RE: something is slipping?
I have the clang as well..... If I ease out theclutch to roll to the end of the driveway, I will CLAAAANG when I pull the clutch back in. Sounds tinny, Almost as though a wrench was dropped on the front fender.
Old May 15, 2008 | 08:23 AM
twincam47's Avatar
twincam47
ORIGINAL: BadPiggy
After thinking a minute...perhaps you meant 1 3/16ths?
In either case, that's still not accurate.
1 3/16ths is the clutch sprocket nut.
1 1/2 is the compensator.
They changed compensators in 2007...it no longer has the 1 1/2 inch nut.........it is a bolt Part # 3368 and is described as 9/16-1/2 X 3 grade 8. It has a 13/16 head.
There is a service bulletin M-1205 that gives a new tightening torque procedure for the 2007 touring models.....the service manual says tighten to 155-165 ft.lbs....the bulletin says to do it this way.....tighten to 100 ft. lbs. backoff 360 degrees and retighten to 140 ft.lbs.
Old May 15, 2008 | 08:48 AM
dawg's Avatar
dawg
The 07 and 08's can make a clatter noise in the primary when first taking off while in the friction zone of the clutch. +1 on twincam's post, the nut changed
Old May 15, 2008 | 10:24 AM
dirtdobber's Avatar
dirtdobber
Thanks guys. I have a slight leak I mean slight, under the primary beside the drain. I will take it to the dealer for warranty and have them check it all at the same time.
I was on a ride for a fallen comrade and played a little, pulled the front wheel off the ground. That afternoon when the bike was cold is when I noticed it. It has only done it twice, the bike was cold both times in about 300 miles. Yes I always allow the engine to build oil pressure before taking off.
I will ride my other bike until I can get it to the dealer. I have a great dealer so I sould have no problems getting it took care of.
I really like this bike.
Again thanks
jim
Old May 15, 2008 | 05:10 PM
jpooch00's Avatar
jpooch00
Dawg,
That's the funniest avatar I've ever seen! I crack up everytime I see it! (it's funny 'cause it's true!).
Ride safe & have a great summer,
John
Old May 15, 2008 | 07:09 PM
dawg's Avatar
dawg
ORIGINAL: jpooch00
Dawg,
John
Oh you bet it's true!
Towneedogg
Jul 15, 2019 01:48 PM
twilliams
21
Nov 11, 2015 07:20 AM
jsmith6752
Jun 24, 2010 05:23 PM
1bagman
Apr 22, 2009 10:54 AM
grounded7
Shovelhead
Jun 6, 2008 08:29 AM
