push rod play
Old May 26, 2008 | 07:16 PM
White Knight 04's Avatar
White Knight 04
Default RE: push rod play
Good advise Coop.... That is exactly the way I adjust mine IE BDC of the cam....
Old May 26, 2008 | 10:42 PM
Hanoverfiste's Avatar
Hanoverfiste
ok, I also found this...
"Verify that you are on the compression stroke of the front cylinder by pacing your finger over the front spark plug hole and have someone rotate the rear wheel until you get a rush of air out of the spark plug hole. This step might not be necessary, but this way I knew I was on the compression stroke with both valves closed"
shorty07ultra
Jun 8, 2015 04:54 PM
swhitinger
Nov 5, 2013 04:27 PM
waynemags
Exhaust System Topics
Jul 14, 2010 10:52 AM
jjclifford
May 9, 2010 03:55 PM
hedotwo
Jun 3, 2008 04:56 PM
