Cam help
Old May 21, 2008 | 06:22 AM
toneman's Avatar
toneman
Default Cam help
Dealer recommends S&S 510g in my 2004 Screamin Eagle bagger.Am doing other mods as well.Looking for more power but don't want to lose bottom end.Most of my riding done around So.Ca. Occasionally I go onovernighters.
Old May 21, 2008 | 06:35 AM
Harleypingman's Avatar
Harleypingman
Default RE: Cam help
Head-Quarters HQ-0034 would be an excellent choice. Do a search and you will find many recommendations for them.
Here's a link to Big Boyz cam comparator that allows you to compare the specs on three cams at once:
http://www.bigboyzcycles.com/tccams.htm
Old May 21, 2008 | 05:38 PM
maineultraclassic's Avatar
maineultraclassic
In a 103", I would highly recommend the Woods TW-6..................great power from idle to redline. Headwork and a bump in compression will make it even better if you ever decide to go that route.
Steve
Old May 21, 2008 | 06:02 PM
PhilM's Avatar
PhilM
ORIGINAL: maineultraclassic
Steve
The exact same is true of the HQ-0034.
Keep in mind Steve, that you really can't compare your bike with 0034's to your bike with the 6's because you did not change "just cams". You changed the cams, the heads, AND bumped the compression.
Old May 21, 2008 | 07:01 PM
Xtreme's Avatar
Xtreme
listen to phil and you wont go wrong he steered me into my hq-tc575 and im gettin over 100 ft torque right at 2000 rpm but im also runnin a 107" inch motor with compression and head work. the hq-0034 will be great in youre bike
Old May 21, 2008 | 07:24 PM
PhilM's Avatar
PhilM
ORIGINAL: toneman
I just noticed you said it was a S/E motor. I assume this is 95" in your 04, right?
It has S/E heads already too, right?
If that is the case, I believe the HQ-0039 is often used as a bolt-in on these bikes. I suggest you give Doug @ HQ a call... he'll help ya get it properly setup..... http://www.head-quarters-usa.com/ushome.html
Old May 21, 2008 | 10:08 PM
Northside's Avatar
Northside
You say you are doing other mods. The cams need to match your heads and compression. More compression will restore a lot of lost low end from longer duration cams. Too much compression and short duration cams don't work well. It's all gotta work together. S&S 510 work well in mild engines.
Old May 22, 2008 | 03:10 PM
Big Peter's Avatar
Big Peter
I'm running S&S .510G gear drive cams in my bike
and bottom end power is great.
www.sscycle.com/modules/instruction/uploads/51-1047.pdf
Peter
Old May 22, 2008 | 03:18 PM
ridesegc04's Avatar
ridesegc04
woods tw5g come on at 2 grand drop a bit at 4 works for me in my 04 electraglide classic check out woods web site dyno runs
kustom78
Oct 4, 2013 02:24 PM
hogkrazy
Exhaust System Topics
14
Mar 28, 2012 05:38 PM
Chad263
Jan 2, 2011 09:00 AM
VTwinPulse
17
Mar 15, 2010 05:27 PM
HD Attitude
17
Nov 25, 2007 10:12 AM
