ARC Audio Mini Amp
Old May 22, 2008 | 03:42 PM
FLHT's Avatar
FLHT
Default RE: ARC Audio Mini Amp
I would be a bit worried about putting this in the fairing
[IMG]local://upfiles/19036/A12CC3422D5B42B5955CDCF36201B943.jpg[/IMG]
Old May 22, 2008 | 04:14 PM
Big Twi$t's Avatar
Big Twi$t
Arc Audio is one the top quality brands in mobile audio. They have a very good following with a very strong reputation. Trust me,that amp is more then likely underrated power wise and that is a conservative power rating.
Every amp has that "small print" for the company CYA. I've put numerous amps on sub boxes, no issues...I've put numerous amps in areas where I thought for sure they would over heat but it didn't. Does this mean this particular amp wont have issues...no...who knows until you try though. For a 1/3 of the price (of the other HD specialty amps) I'll give a brand name that I'm familiar withand trust a try first. Plus, I know some little tricks that may or may not work to helpif a problem does arise.
Basically, if you are not sure...spend your money on the other equipment. Like I mentioned before...I can probably sell my stock HK HU and cover the priceof all new aftermarket equipment and I'm certain that it will sound better too.
Old May 22, 2008 | 04:26 PM
FLHT's Avatar
FLHT
Whats the price of this amp and where can it be bought ?
Old May 22, 2008 | 05:05 PM
hardluck21's Avatar
hardluck21
I plan on mounting the amp in the fairing in the same location the Hawg-wired amp mounts.
Because it is 80% efficient there should be little concern on heat dissipation, but I would ask the dealer about a suitable location.
The amp is rated at 70x2 RMS at 4 ohms and is stable down to 2 ohms at 125 watts RMS. Some shops are installing one of these powering the front fairing and tour pack speakers in parallel resulting in a 2 ohm load. This will cause the amp to work harder but it is rated for it and ARC Audio is a high quality brand, above Pioneer, JVC, Alpine, etc.
If you go to Modesto Harley in California Website they offer a complete system install and claim they have tested every system out there and this is the best.
Old May 22, 2008 | 05:40 PM
restorick's Avatar
restorick
ORIGINAL: FLHT
You need to find a local dealer, or you can contact them direct and purchase. I don't have a dealer in town that carries ARC, so I called a couple from the dealer locator to see if they would ship. Some will, and they might discount slightly. Expect to pay between $300 and $330 shipped to your door. I believe MSRP on the amp is $329.
I've read a number of pro reviews of ARC amps and equipment, and they are first rate. Clean power, low heat and small footprint. Almost sounds like they designed this amp to compete in the faired bike world.
They also have a 4 channel mini to be released very soon, and all indications are that the chassis won't be much larger than the 125.2 mini. That's just the scuttlebutt from a dealer, not the company...
Resto
Old May 23, 2008 | 12:13 AM
crzrdude's Avatar
crzrdude
+1 I got the same info. on that amp. The auth. dealer for the amp in my area has installed many mini's on EG and RG. They have MgGuires HD down the road and told me they have been doing lots of installs with no problem. The amp fits in the fairing just like theHawg Wired unit and is very popular with all the stereo heads.
ARC audio is soon releasing the 4 channel mini not too much bigger than the 2 ch. This amp paired with morrell speakers would be a great match.
tans66
Audio Systems
54
Jul 2, 2017 11:00 PM
FrenchieM
Audio Systems
Jun 30, 2017 12:20 PM
PostalRoadKing
Audio Systems
May 29, 2017 07:24 PM
iMAK79
Audio Systems
Aug 10, 2014 10:57 PM
mphillips21
Audio Systems
Aug 29, 2013 12:12 PM
