08 FLHRC Risers
Old May 23, 2008 | 04:30 PM
Dickf5187's Avatar
Dickf5187
Default 08 FLHRC Risers
I have my bike setup the way I want it with the exception of the handlebars. HD hasn't released much in the way of bars. I like the spread and grip angle of the stock bars except that I'd like to have them up about two inches and back an inch or so.
I see that HD makes a cover Harley Part Number 55854-07 Slammer Handlebar cover which allows the use of risers. Sounds like a perfect solution to bring the bars to the correct position for me.
Anyone done this or seen it? If so are the cables and brake line lengths OK? I know there is plenty of clutch cable. Thanks.
Old May 23, 2008 | 05:14 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
Default RE: 08 FLHRC Risers
brake line and wires will be tight dont know how much rise youll get with the kit but if u go with a narrower bar it gives more lenght for the added height not sure what bars u can use with the fbw though.
Old May 23, 2008 | 09:51 PM
fruit's Avatar
fruit
dickf5187, i put 4 inch pullback risers on my wifes 08 rkc because she wanted the bars to do the same thing that you wantand there is plenty of wire and slack in the brake lines her bike has abs also. that cover that hd sells will work great.
Old May 24, 2008 | 06:49 AM
Dickf5187's Avatar
Dickf5187
Fruit, thanks for the response. This prompts a few more questions. Did you use HD rsers and if so which ones did you use? How about appearance? The stock setup is pretty clean. Look OK to you?
Again, thanks for your help.
Old May 24, 2008 | 07:42 AM
fruit's Avatar
fruit
dickf5187,here are some pictures of what i did the risers i got off of ebay for 45.00 with the top clamp. as you can tell i did not change the center trim i drilled the holes in it for the risers to come out the top. hers is a little more cluttered up with the rumble road speakers on because of the extra wires so if you get hd's cover it should be a real clean install.
Old May 24, 2008 | 10:42 AM
Dickf5187's Avatar
Dickf5187
Fruit... you're a gentleman and a scholar! Thanks for all your help and the pictures. Ride safely!
Gar1414
Apr 22, 2021 08:57 AM
smokinbutts
Aug 21, 2013 03:39 PM
tray45
Jun 7, 2011 04:11 PM
mnelson37
May 7, 2010 03:59 PM
Frog74
Jan 25, 2008 08:25 PM
