Front Fender Removal Shortcut?
Old Feb 27, 2006 | 10:42 PM
mchacon's Avatar
mchacon
Default RE: Front Fender Removal Shortcut?
What do you mean by pick it out?
There is no crease and I polished out the surface scratch. THis would be a great option
Old Feb 27, 2006 | 11:01 PM
spartns's Avatar
spartns
There are special auto body tools that can get behind a dent and "lift" it up. It takes time as you must go VERY slowly. I didn't have the special tools, I used a hammer handle. But as I mentioned, I've been doing this for years. Give it a try, you're gonna have to have it repaired anyway. Start at the point that was damaged last. In other words, if the impact was from front to back, start at the back. Very gently pry, lift, the dent out from back to front. DO NOT get in a hurry. It might take an hour to do the job. Just go slowly. You've got nothing to lose, go for it. Just remember, go slow. If you raise it too much,well, you've got another problem. Good luck.
Old Feb 28, 2006 | 03:26 AM
mchacon's Avatar
mchacon
I'll give it a shot and see where it goes from there. The dent runs across the top of the fender directly underneath the light bar.
I wonder what a paintless dent repair joint would charge?
Old Feb 28, 2006 | 10:30 AM
billnourse's Avatar
billnourse
Without removing the fender is is very difficult to get to the locking tabs that are on the front fender bolts. Some people have done it by unlocking the tab from the opposite side with a long screwdriver. It is much easier to take the wheel off.
Regards,
Bill
Old Mar 3, 2006 | 01:46 AM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
I did mine without pulling the wheel, I pulled the calipers you'll need a 12 point 10 mm socket for this, and then I got a 9/16 socket on an extention, went in from the other side, and beat the extention with a hammer to get the locking tabs to flatten out. you'll need to roll the bike forward to get all 4 bolts out
As for the dentless removal... forget it. I had the same problem with my bike ( btw go to thicker fork oil)
these fenders are made of real metal, and any massaging is going to crack the paint.
you can hammer, dolly pick and file the majority of the dent out. if you have the time, and the tools, and the patience.
I picked and filed 99% of my dent out, then skim coated it with the newer everglaze putty. prime and painted after that.
Old Mar 3, 2006 | 09:57 AM
daboys53119's Avatar
daboys53119
I have heard that you can remove non-creased dents with dry ice. Apply dry ice to dent location and then apply heat. I am guessing a heat gun on low setting very carefully. The rapid temperature change causes the metal to expand and the dent pops right out. Never tryed it but sounds like it may work. I have some wholesale cars here the I could use as a test if you want.
Old Mar 3, 2006 | 10:42 AM
jfanton's Avatar
jfanton
ORIGINAL: spartns
You may be getting ahead of yourself. You can remove a fairly large dent without removing the fender. As long as it's not creased, you, or someone, should be able to do it. Example, I was unloading some lumber from my truck. The bike was parked behind the truck. Yup, I pulled a couple of 2X4s out and hit the fender. About a 3" dent. I'm an old auto body instructor, I took my time and picked it out. There is no evidence that there was ever a dent. Check your body shops or the Yellow Pages for Paintless Dent Repair.
I have had many (non-creased) dents removed from various auto's over the years and still continue to use these "artisans" to this day.
Should cost no more than $75.00 for a single dent. They are listed in the yellow pages. Once you find a good guy, stick with 'em.
po1192
Nov 7, 2024 07:27 PM
Ashnic
Milwaukee Eight (M8)
Oct 3, 2017 11:40 AM
Ozark Joe
EVO
15
Nov 22, 2016 12:26 PM
RKC1965
2014-2024 Touring Models
Sep 12, 2016 07:25 AM
mikeboztx
May 2, 2008 12:19 AM
