DYNO Numbers for Baggers???
Old Feb 16, 2012 | 08:48 PM
  #3221
jackhis's Avatar
jackhis
Originally Posted by Lonewolf176
Sure, that's part of tuning. 0,2,5,7,10,15,20,25,30,40,60,80 and 100% tp's, each cylinder. While you can look at torque and hp you are looking at the afr line to calibrate the ve tables. Here is before and after afr lines at 20,40 and 60. Target afr for tuning is 13.5 to reference a straight line and then changed to different values once calibrated.
I see!
But then the a/f ratio without a relative HP, and torque will not be helpful to me, or any.
Do you have another graph that contains ALL the info: a/f, RPM @ each TP, hp, torque?
Old Feb 16, 2012 | 09:07 PM
  #3222
Joker65's Avatar
Joker65
Just found this chart from last year.... completely forgot about it!
Anyway, she's running well and keeps cool all day long!
- 103" Build, (+0.010")- Wild Thing TC-26D Cam
- 54 mm HPInc TB
- Fuel Moto Header Pipe
- Crusher Slip-ons
- 10.8:1 CR
Attached Thumbnails  DYNO Numbers for Baggers???-103-tc-26d-54mm-fm-x-pipe.jpg
Old Feb 16, 2012 | 09:48 PM
  #3223
jackhis's Avatar
jackhis
- 54 mm HPInc TB
- Fuel Moto Header
- Crusher Slip-ons
- 10.8:1 CR
Very nice!
Old Feb 16, 2012 | 10:21 PM
  #3224
Deuuuce's Avatar
Deuuuce
Originally Posted by davewear
of course it does, the chart you get from your dyno run shows full throttle thru all rpms fom the start.
what it doesn't show is how much power you are making at part throttle at any given rpm.
Depends on the dyno operator and parameters selected, of course.
Originally Posted by jackhis
Yes, that's what I've meant!
That's exactly what I 've said earlier, the HP and torque from the Dyno doesn't mean much, as many posts have misled.
Again, the "riding range RPM" is what counts, as that is the real HP, and torque is produced at that RPM and the TP relatively. Obviously, the power (HP & Torque) will be lesser than the reading from Dyno.
I am wondering whether anyone has done the Dyno at 20%, 30%, and 50% TP, rather than 100% WOT.
I see!
Yes, but that is a 3-dimensional graph.
A good tuner will tune for absolute power (WOT) and make adjustments at partial throttle for mileage, flat spots and rideability. Most of the guys here though are posting their peak power.
Old Feb 16, 2012 | 10:36 PM
  #3225
jackhis's Avatar
jackhis
I love to see one! It must include 3 axises, I guess. But then, I don't know!
Old Feb 17, 2012 | 01:08 AM
  #3226
Lonewolf176's Avatar
Lonewolf176
Here's one that shows "step" testing at 5,7,10 and 15% throttle. Second one is the same bike at wot. Even the step testing isn't indicative of the power, for example on the 15% "run" the kpa at 1500 is probably 80+ kpa, and at 4000 rpm it is maybe 35-40. The way to test it is to use the torque module on the dyno and to adjust the load on the brake to hold the bike at a certain kpa (load) at a specific rpm. This is done to optimize the timing in the "cruise" area of the calibration. This isn't done on most tunes as most dyno's don't have the torque modules.
Attached Thumbnails  DYNO Numbers for Baggers???-step-testing-5-7-10-15-.jpg    DYNO Numbers for Baggers???-wot.jpg
Old Feb 17, 2012 | 01:17 AM
  #3227
GBond's Avatar
GBond
4th Gear
looks very good, like the fact that the power looks to be in the midrange. how is that accomplished?
Old Feb 17, 2012 | 01:38 AM
  #3228
davewear's Avatar
davewear
In your opinion is this something one should ask to see from their tuner?
I have had 3 of my Harley's dyno tuned and I've never seen a chart like this. I've seen maybe 100 charts online and never seen this. Seems like it would really tell if you're getting a good tune or not....
Old Feb 17, 2012 | 07:54 AM
  #3229
CaboWabo5150's Avatar
CaboWabo5150
What do you think made the difference in mpg?
Break in... New valves in new heads.. Just needed to get them broke in...
Old Feb 17, 2012 | 08:06 AM
  #3230
coolerman69's Avatar
coolerman69
It'll get better. At 6000 miles mine would get 52 if the laws weren't broken. At 16000 it still will but I usually don't ride it that way.
