I am learning, so what RPM does the Dyno shows, if it is not the same as the RPM on the speedometer?
Please give me more info.
The dyno sheet shows WOT, or when you have the throttle open 100%. When you are cruising at 2500-3000 rpm your tp will normally be anywhere from 10-20% (the bigger the engine, the lower the tp). On a wot pull on the dyno the manifold pressure (map) will be around 100 kpa (depending on elevation). Cruising down the highway you will be around 40-45 kpa, again each bike will be a little different. A lot of the tables in your calibration are kpa/rpm based. When you are running down the highway at 3000 rpm you are in a completly different "area" of your calibration than when viewing a dyno sheet.
That is one of my complaints, I feel I need to keep the rpm's up to high for the power. you think maybe the cams could be the problem? I have been reading other forums and seeing better results with different cam setup.
Cams are definitely your problem. 257s are race cams. My motor was built to run 1/4 miles at a time in a quick manner. Not cruising friendly to most riders. I'm one of those 0-80 jack rabbit types so it suits me. I love dumping the clutch in 2nd and doing a smokey burnout. If you keep the 257 cams you will shift a lot more than your buddies, but you will also out run most of them.
Thanks for the info, but it does not apply to my question.
What I have meant before is, let's say, at 3000 RPM, the Dyno says 50 HP/100 ft/lbs, for instance, then while riding at 3000 RPM, then engine will produce maximum 50 HP, or less.
SO, the 3000 RPM on the Dyno should be the same as 3000 RPM on the speedometer, regardless the TP.
Please correct me, if that is the case.
the speedometer does not read rpms, if you meant to say tachometer then yes.
3000rpms at 50% tp will not produce the same numbers as 3000rpms at wot. Dont quote me on that!
don't think that's what he's asking? i think he was asking if the rpms on a dyno would be the same as what was shown in the tach, regardless of tp. obviously tq and hp is going to be affected by tp.
i would be happy with 40 mpg. have over 10k on this setup. maybe have other issues, I am on my 4th (you read that correct fourth) throttle body in less than 3 years. the last HD shop found some bad sensors, we will see if it helps when the weather gets better.
Yes, that's what I've meant!
That's exactly what I 've said earlier, the HP and torque from the Dyno doesn't mean much, as many posts have misled.
Again, the "riding range RPM" is what counts, as that is the real HP, and torque is produced at that RPM and the TP relatively. Obviously, the power (HP & Torque) will be lesser than the reading from Dyno.
I am wondering whether anyone has done the Dyno at 20%, 30%, and 50% TP, rather than 100% WOT.
Sure, that's part of tuning. 0,2,5,7,10,15,20,25,30,40,60,80 and 100% tp's, each cylinder. While you can look at torque and hp you are looking at the afr line to calibrate the ve tables. Here is before and after afr lines at 20,40 and 60. Target afr for tuning is 13.5 to reference a straight line and then changed to different values once calibrated.
