DYNO Numbers for Baggers???
Old Apr 5, 2012 | 01:05 PM
  #3311
HDWRENCH's Avatar
HDWRENCH
Default 2005 RK 120R crate engine
specs 2005 RK
stock 120R engine
Sampson 1 3/4 t dual pipes crusher mellows
HPI 58 t/b
HPI high pressure reg
6.2 injectors
bandit clutch
zipper high flow cleaner
tts tuner.
His old build was a 95 with the same ex with a mystery slip on, SE 257 cams.
We did try the open crusher muffler as well, and lost power.I do think a power X head pipe would have shown more gains but not in the cards on this build.
Old Apr 5, 2012 | 01:06 PM
  #3312
HDWRENCH's Avatar
HDWRENCH
Default 2012 CVO 110 with bolt in cam
2012 base as 100% stock bike. ( yes it did ping the afr line is correct..17.1+ afr in stock form)
Bolt in andrews 57 cam
Crusher power x and mellow mufflers
mach 5 a/c
tts tuner.
no other engine mods.
Tq comes on fast and pulls out very well.
Attached Thumbnails  DYNO Numbers for Baggers???-2012-cvo-110-bolt-in-cam-e-mail.jpg
Old Apr 5, 2012 | 01:09 PM
  #3313
HDWRENCH's Avatar
HDWRENCH
Default 2011 103 54 cam swap from 255 dealer build
We swapped out the 255 cam from the dealer 103/ 255 build. Installed the 54 and a .030 h/g. Customer wanted to have cylinders/ pistons inspected as the bike had been running hot and pinging badly. The run on the sheet is what we got as the customer got it from the dealer.
Attached Thumbnails  DYNO Numbers for Baggers???-bob-w-2011-103-54-cam-crusher-e-mail.jpg
Old Apr 5, 2012 | 01:21 PM
  #3314
HDWRENCH's Avatar
HDWRENCH
Default 2011 120R with GMR dome pistons
Here is a 120R with our pistons and a zilla pipe SE 58 t/b that was bolted together. As you can see the low end tune could use a bit of work. Overall customer is thrilled over the stock 120R engine. Customer had a dealer in Louisiana do all the work.
Attached Thumbnails  DYNO Numbers for Baggers???-120r-with-gmr-piston-2011-001.jpg
Old Apr 5, 2012 | 09:46 PM
  #3315
Bobo2011SG's Avatar
Bobo2011SG
2011 SG 103" Power Pak 6,000 miles
SUPERTRAPP STOUT,HD FLH/FLT '10-11 140-65224
SE Ventilator Intake
Stock head pipe with gutted cat
SE Super Tuner
Andrews 48H Cams
Wrenched/Tuned by Aaron at Kutter HD in Janesville, WI
Old Apr 6, 2012 | 04:07 PM
  #3316
vstewart5's Avatar
vstewart5
Stage IV
Default 2005 flhtc
Here is mine:
2005 Electra Glide Classic
103 screamin eagle upgrade
257 cams,performance heads,rinehart duals,se air
109.12HP and 112.13 torque
Old Apr 6, 2012 | 06:49 PM
  #3317
coolerman69's Avatar
coolerman69
Originally Posted by vstewart5
Here is mine:
How you like those 257s?
Old Apr 7, 2012 | 08:56 AM
  #3318
HD Street Glider's Avatar
HD Street Glider
Stage II
2011 Street Glide with 103 power pack.
Just had some performance upgrades installed last week and very happy with the results.
Upgrades: Screamin Eagle Oval Ventilator, E255 cams, Vance & Hines X-pipe headers, TTS Tuner, and 4"Rinehart slip-on Exhaust.
Dyno Numbers: Max Torque = 110.14@3700RPM & Max HP = 93.27@5400RPM
Old Apr 7, 2012 | 09:15 AM
  #3319
HD Street Glider
Stage II
Your Numbers are very close to mine, impressive!
Here's mine:
Just had some performance upgrades installed on the Harley last week and very happy with the results.
Old Apr 7, 2012 | 04:25 PM
  #3320
msocko3's Avatar
msocko3
Default 120" Head Quarters Build Tuned By JD's Cycle Works
Built a 120" HQ but opted to use the 0033g cams vs the 575's to drop the CCP down some. Dave at JD's cycle works did a heck of a job on tuning it, the short ride I had has me grinning from ear to ear. Wasn't trying to rotate the earth or try for max HP or torque, just looking for a solid reliable build that I can ride the snot out of. Build also shows the Supertrapp Supermeg works pretty good with bigger inch builds, have 25 disk and a close end cap on this one.
