DYNO Numbers for Baggers???
Old May 29, 2012 | 10:57 PM
  #3411
crash1969's Avatar
crash1969
Stage II
Default 103 , 255, pro tuner, rhinehart with vance and hines slip ons
how does the chart look?
Old May 30, 2012 | 09:55 AM
  #3412
Grappa's Avatar
Grappa
Ok so just got my 2012 FLHTK back after having the following installed:
Jackpot 2-1-2 Ceramic Headers, SE Stage 1 A/C, SE 255 cams, S&S Quiet Tour Mufflers, Power Commander V.
This was done at about 1300 Miles
and here are the #'s.
Before: Max Power = 64.80 Max Torque = 81.92
After : max power= 82.73 Max Torque = 99.71
Not sure how these compare, I thought the numbers should be a bit higher, yet I haven't seen anyone wih the same combination. I've ridden about 400 miles since the change and had problems over the weekend, both engine, and battery lights came on and she started some loud ping when blipping from start up in traffic. Pulled over and waited about 5 and started , lights were out, that lasted 5 or 10 minutes, not in traffic anymore... Let sit for an hour and headed back home halfway there, both lights on and rear cyl feeling pretty hot and hear a whirring sound. Limped home and now she is on the way to the shop....
They think it might charging system/battery, but why would that cause excessive heat in rear cyl. Sound like it could be a combination of things to me, stator bad, battery, but also maybe a problem in timing?? WDIK?
Anyway we'll see.
Anyone have a similar setup to compare #s
Old May 30, 2012 | 02:28 PM
  #3413
1hd08EGC's Avatar
1hd08EGC
Just got my ride back today.
2008 EGC
103 Kit
255 Cams
Race Tuner and SE Air Filter
SE Slip ons (been on for a few years)
86.81 hp and 102.36 tq
Old May 30, 2012 | 03:43 PM
  #3414
Lonewolf176's Avatar
Lonewolf176
It would be easier if the dyno operator used the "forced scaling" button when he printed the graph.
Old May 30, 2012 | 06:12 PM
  #3415
08streetsweeper's Avatar
08streetsweeper
3rd Gear
I can't figure out how to post a pic of my sheet on here as I'm on my phone...
Old May 30, 2012 | 07:16 PM
  #3416
Sparkey II's Avatar
Sparkey II
4th Gear
Default Dyno numbers for baggers
2010 Limited 103 with V&H Power Duals / V&H Monster Ovals / K&N AC / Thuandermax auto tuner. Dynoed at 79hp an 86 ft lbs torque. I traded this one and will have print out for the new 110 CVO in a couple weeks. Doing some mods to the new one now.
Old May 31, 2012 | 09:59 AM
  #3417
producer's Avatar
producer
maybe hang the phone up?? No serious, get a hold of one of the administrators such as TERRY1955. you may need some account options turned on, in order for attachments to be uploaded.
Producer
Old May 31, 2012 | 12:38 PM
  #3418
Denvince67's Avatar
Denvince67
2nd Gear
Default Altitude
2008 Streetglide
SE cam
SE pistons
ported and polished heads
bee hive springs
adj. pushrods
Rhinehart tru duels
SE air cleaner
107hp
110 torque
@ 5280 ft
How much more do you think I would have at sea level?
Attached Thumbnails  DYNO Numbers for Baggers???-aa1.jpg    DYNO Numbers for Baggers???-aa1b.jpg
Old Jun 1, 2012 | 10:11 AM
  #3419
crackers's Avatar
crackers
First run and last
Old Jun 3, 2012 | 03:59 AM
  #3420
Bagless Bagger's Avatar
Bagless Bagger
2010 FLHX with Arlen Ness Big Sucker Air Cleaner & Vance and Hines Pro Pipe 2-1 black, dynoed at 76 hp & 86 ft lbs on a stock 96".
