DYNO Numbers for Baggers???
Old Feb 25, 2007 | 02:15 AM
  #381
jj9150's Avatar
jj9150
Default RE: DYNO Numbers for Baggers???
dyno'd the SG today after my maintenance, motor is still pretty tight so i am sure the numbers will improve with some more mileage.
71 Hp 84lbs torque
rinehart td's
ness big sucker II
pcIII
elevation 2500'
humidity only 7%
also dyno'd my 13 year old crotch rocket to for the hell of it 115hp 65lbs torque
Old Feb 25, 2007 | 05:33 PM
  #382
maineultraclassic's Avatar
maineultraclassic
ORIGINAL: Shawn ultra
02 Ultra
95" s/tb se a/c w/ness filter
sbc mild ported heads bigger valves (1mm) 600 lift springs spin drop
.0030 cometic h/g 9.7 9.8 c/r 190/190 f/r ccpr
se f/t pistons w/valve relief
andrews 26g cams
r/h t/d
sert
107.5 tq
100 hp
trying to find a way to show dyno sheet
At 9.8-1 with the 26G.............I would expect some major pinging. I'm nervous at 9.6-1 with them.
What are your 4th gear SAE numbers?
That's a hell of a pull for that build, first time I've ever seen 100/100 with a 95"/26G build.
Steve
Old Feb 25, 2007 | 07:10 PM
  #383
Road Warrior's Avatar
2007 Road King
RaceTuner
SE Air filter
Kerker P.A.T. Slip-on's
71hp 83tq
Old Mar 3, 2007 | 01:46 PM
  #384
raym's Avatar
raym
I got an '05' Road King Custom, Screaming Eagle air cleaner, Rush slip on pipes - 2" baffles, and SERT.
70.60 HP, 78.39 Ft. Lbs. torque. Max power was at 4000 - 4200 rpm
Old Mar 3, 2007 | 01:55 PM
  #385
raym's Avatar
raym
Screaming Eagle slip on's. I've got a set I will sell you that are in good shape. They sound almost like stock pipes and I bought a set of Rush pipes because I wanted a little louder sound. I then had to buy a SERT and have the bike dyno tuned just to get the torque back to where it was prior to installing the Rush pipes.
This has sold me on the performance of the Screaming Eagles and if I don't sell them soon, I might be inclined to put them back on the bike.
These state on the pipes "not for street use. For enclosed track only". or something to that affect. They are not being advertised on ebay or anywhere else at present because I haven't completely convinced myself to sell because you can't buy these anymore.
Ray
Old Mar 5, 2007 | 03:40 PM
  #386
hotpursuit's Avatar
hotpursuit
ORIGINAL: daltonhg
03 Road King Classic bored to 95"
HTCC Pistons
HTCC Heads
Woods TW5G cam
K&N
Rinehart True Duals
PC III USB
102 HP 112 ft. lbs. TQ
Am currently building my 07 Ultra
bored to 103"
Woods TW-400-6 cams
HD CNC Ported Heads
HD Flat top pistons 10.5:1
HD 50mm throttle body
Rinehart True Duals
PCIII USB and a few other small goodies, am expecting to hit 115 HP and 125 ft.lbs TQ
nice numbers on the 03... im fixen to do about the same on my 06 standard
Old Mar 8, 2007 | 01:27 PM
  #387
Neckball's Avatar
Neckball
I know what you mean. I took off a set of SE II's and put on Wild Pigs with 2" baffles. Absolutely killed the bottom end torque, I could tell before I got all them way through second gear on the first ride with the WP's. Really a disappointment. I put in some lollipop baffles and it helped a little. After about 2 months I put the SE II's back on, torque came back immeditately.
Old Mar 8, 2007 | 07:04 PM
  #388
eharms325's Avatar
eharms325
Here's my #'s from today. Blue #'s are from the sert map and the red are from tuming.
I have an 07' FLHTC
Ness A.C.
Rinehardt T.D. exhaust
86.95 Torque
74.73 H.P.
[IMG]local://upfiles/23522/672203A5CD2C4DE5AA3C26FAA6BBECC5.jpg[/IMG]
Old Mar 9, 2007 | 01:15 AM
  #389
coyotedata's Avatar
coyotedata
07 SE Ultra
Rinehart True Duels
SE Air
SERT
[IMG]local://upfiles/20514/6180A89AC72047A0BF347BD59E8D56D2.jpg[/IMG]
Old Mar 9, 2007 | 01:37 AM
  #390
eharms325's Avatar
eharms325
ORIGINAL: coyotedata
07 SE Ultra
Rinehart True Duels
SE Air
SERT
If that's stock other than exhaust and a/f, someone needs to fix that dyno. You aint squeezing that much torque or hp out of a stock engine.
