DYNO Numbers for Baggers???
Old Aug 24, 2008 | 04:30 PM
  #881
Mike7111's Avatar
Mike7111
4th Gear
The before numbers are after I installed everything but the SERT...
Before. 72.2 HP...84.4 Torque...14.7 AFR.
After. 77.2 HP...85.1 Torque...13.3 AFR.
I wish I had an idea of what it was from the moco.
Old Aug 24, 2008 | 06:24 PM
  #882
Ultra61's Avatar
Ultra61
That is almost one of the nices bikes I have ever seen.
#'s are good enough w/ true duels...spend the money for the SERT only to get worst fuel milage...been there done that
Old Aug 24, 2008 | 07:09 PM
  #883
The Nev's Avatar
The Nev
Well here's mine although I don't have a copy of the chart.
06 Ultra Classic Jugs bored to 95" Wiseco falttop pistons, heads ported and polished with bigger valves, Andrews 37G gear drive cams, Zipper high flow air cleaner and Fat Cat 2 into 1 exhaust. Thunder Max ECU
103HP
107TQ
Old Aug 25, 2008 | 07:52 AM
  #884
fxrs88apes's Avatar
fxrs88apes
2nd Gear
84 hp@5000rpm
90 tq@4500rpm
98 evo flhtcui
PCIII
Kerker slip-ons right side baffles punched out
EV27 Andrews
Heads by Zandi's (Sussex WI)
SE pop-ups w/red injectors
Stock Sucks
Old Aug 25, 2008 | 10:40 AM
  #885
HarleyJeff's Avatar
HarleyJeff
4th Gear
Default My Dyno Numbers
I don't have a stock baseline and sure wish I did one before the changes but here's what I have.
Mods are;
BuB 7 true dual pipes
Cycle Visions MoFlo A/C
Before SERT
88.06 HP
107.77 TQ
After SERT & Dyno Tune
98.53 HP
118.37 TQ
Old Aug 25, 2008 | 10:50 AM
  #886
masterblaster's Avatar
masterblaster
jeff what size is your engine?
Old Aug 25, 2008 | 10:58 AM
  #887
HarleyJeff's Avatar
HarleyJeff
4th Gear
Hey Masterblaster its a stock CVO SE 110"
Old Aug 25, 2008 | 05:22 PM
  #888
Mr Zip's Avatar
Mr Zip
121 HP, 113 ft lbs of torque -- Screamin Eagle 103
mods are:
-SE heavy breather filter
-Vance & Hines 2 in 1
-50 mm throttle body
-low profile stroker pistons
-C&C Ported heads
-Stroker Crank and Flywheel
- SE Roller Rocker arms
-SE Cams
-Race Tuner
Old Sep 1, 2008 | 12:29 PM
  #889
GasCan's Avatar
GasCan
2007 Streetglide
124" Jim's Crank/Rods
Axtell Jugs / R&R Heads
HPI 55MM 5.06 GPS
640 Gear Driven
Boarzilla Pipe
SE Super Tuner
130HP/133TQ / SAE Corrected
Old Sep 2, 2008 | 06:51 AM
  #890
grbrown's Avatar
grbrown
I have a new S&S V107T in my old dresser, with Samson true duals and S&S OPS mufflers. At just 1500 miles gave 103bhp and 102ft lbs torque.
