DYNO Numbers for Baggers???
http://www.cvoharley.com/smf/index.php?topic=59556.0
09FLHTP, 103 Stage 1 from Fuel Moto, air cleaner, Jackpot mufflers and Power Commander V. I did not like the Jackpots, too loud for me, pulled the S&S SPO's off of the 02FLHPI and swapped them. Momma was happy with the Jackpots and I love those SPO's, deep rumble but not loud. I don't mind riding next to Jackpot's all day, but didn't like them on MY bike. This last fall I picked up a set of slightly used SE255's pulled from a new SE110 and had the local Indy install them, Fuel Moto sent me their map for this setup, F/M maps are all 95% or better of a full dyno tune. They have seen most all setups and tuned them in house, really impressed with their "canned" maps.
Anyway, the B-Glide pulled 86.66hp / 100.76Tq on the canned map. PULLS hard from 2K, tops @ 2800rpm. Slight dip, may tweek on it, maybe not. Not bad for a canned map, I'm a happy camper.
IF I bought a designer set of cams could have been better, but picked these up for $100! And I was looking for max torque @ low rpms.
This is NOT my hotrod, Bobber is that. It runs great, gets 40-43mpg.
IF you can get this # out of a Stage 2 w/SE255's, you will be happy!
Dan B.
Central KS.
Dan B.
Central KS.
Great guys to work with. Real happy with the results, scoots along pretty good!
Purchased a D&D Fatcat 2-1 exhaust on ebay, can't wait to get it on and see if that helps the lower RPM area a bit and maybe takes the numbers up a little. Overall REAL happy!
Those heads are breathing real nice.
The tuner said they were surprised it was still pulling at 6400 but cut it off there because I didn't have the crank done.
Latest member of the 120+Hp club! We built Johnnie E's engine a couple years back, last week we took this 107 to the next level. We installed FM Level B CNC heads, set comp to 10.75, Wood TW8-6 cams, and dyno tuned it with Dynojet Power Vision. Awesome combination, thank you Johnnie for your continued business and support!
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Bike runs great with F/M map. I am very rarely @ WFT.
Normally run 2200-3500rpm. Look at the dyno sheet and tell me I can do better. All the torque is between 2200 and 3000. This iS GOOD RUNNING twinkie.
If you are not happy with 86hp/101 tq below 3K, you are not me.
Yes I know that there are better # from other combos and dyno's. I'm happy with my cheap easy #.
Do you ride a Dyno or ride your bike?
Dan B.
Central Ks.
