DYNO Numbers for Baggers???
Old May 8, 2014 | 02:51 PM
  #4541
stan60's Avatar
stan60
Must have been built on a Wednesday......
Old May 8, 2014 | 02:57 PM
  #4542
1badsilverback's Avatar
1badsilverback
2nd Gear
Originally Posted by 1badsilverback
I finally had my 2011 FLHTK dyno tuned yesterday after taking a year to finish the Stage 1 (Screamin Eagle mufflers, Arlen Ness Super Sucker, PCM V). I also decatted the header myself. I'm happy with the results and the difference is very noticeable:
HP: 84
Torque: 102
OK, admittedly I rounded the wrong direction on torque...
hp: 83.61 (from 73.98 w/PCM stock tune)
torque: 101.06 (from 89.16 w/PCM stock tune)
Attached Thumbnails  DYNO Numbers for Baggers???-stage-1-dyno-tuning-graph.jpg
Old May 8, 2014 | 02:59 PM
  #4543
1badsilverback
2nd Gear
No need to be slanderous my friend. Facts are facts; dyno graph posted.
Old May 8, 2014 | 03:11 PM
  #4544
stan60's Avatar
stan60
Nothing slanderous intended. Wednesday's are exceptionally good build days. No Monday morning hangovers and no gettin ready for the weekend Fridays. People are dialed in on Wednesdays. That is also a fact. You have my congratulations on having an extremely strong stock stage 1.
Old May 8, 2014 | 03:17 PM
  #4545
1badsilverback
2nd Gear
Duly noted! I haven't turned a wrench for pay in 20 years. Now that you've said that I remember those "light schedule" Mondays. Ironically, all the techs at the shop I go to have Sunday/Monday off! Thanks man.
Old May 9, 2014 | 11:27 AM
  #4546
badpig173's Avatar
badpig173
2008 FLHX
96 c.i. S&S super stealth air cleaner, V&H slip-on mufflers, stock headers, PCV
77 H.P. 78 TRQ
Old May 12, 2014 | 12:16 PM
  #4547
Allison Wunderland's Avatar
Allison Wunderland
2010 FLHX Street Glide -- 36K, 96" TC
SE Stage I, K&N cleaner
Vance & Hines Power Duals, 4 1/2" Monster Rounds
Torque curve is pretty flat from 3K to 4.5K -- 85.69 ft lb
Hp max is 74.31 at 5.2K
Tuned at 81.03 F and 31% humidity -- On a Wednesday! *LMAO*
Old May 13, 2014 | 08:06 AM
  #4548
C.H.L.'s Avatar
C.H.L.
Sorry, but for me, pictures don't prove UFO's, Bat babies, or stage 1's on pre-14's having over 100 TQ....... Again, just me.
Old May 13, 2014 | 03:00 PM
  #4549
1badsilverback
2nd Gear
Honestly I wouldn't have believed it either and I sure wasn't expecting it. I watched the last run and asked for the print out because my entire family rides and would call BS on a Stage 1 with 100+ for torque. When I spoke to the techs about the torque numbers they attributed them to the head pipe being decatted. So I guess the 2 hours of work I put into that project and the $30 i spent to get it welded back up yielded me more than just reducing the header temperature. Either way, it better than stock. I figured on some bias when I posted the numbers... like I said, I wouldn't have believed if I hadn't seen it.
Old May 13, 2014 | 03:16 PM
  #4550
BlackSpecial's Avatar
BlackSpecial
One thing that makes the numbers high is the STD correction. It's always going to be higher than SAE, which is pretty much the more standard correction factor you will see on most dyno printouts.
You should ask for the SAE printout that shows the conditions and correction factor.
