DYNO Numbers for Baggers???
Old Apr 3, 2017 | 08:33 PM
  #5541
Heatwave's Avatar
Heatwave
Member
My 2017 CVO Limited Stage IV SE Street Cannons. 128/128. Runs terrific EVERYWHERE. Not too bad for all Harley internal parts.
Old Apr 4, 2017 | 06:34 PM
  #5542
BigRedUltra's Avatar
BigRedUltra
Beats the heck out of my 103 with TTS Master tune.
Old Apr 8, 2017 | 06:23 AM
  #5543
sporacer's Avatar
sporacer
2016 cv0 streetglide
113 mahle 10:5 to 1 pistons Heads will be decked to get 10:8 to 1 with a .030 gasket
stock cylinders bored
Tman 590 cams
SE 58 throttle body
SE 5.3 injectors
TTS tuner
fuel moto xxx head pipe
crusher mufflers
Attached Thumbnails  DYNO Numbers for Baggers???-received_10210816946411898.jpeg
Old Apr 12, 2017 | 10:43 AM
  #5544
Face84's Avatar
Face84
Stage II
Default Dyno chart
Rhineharts 2 into 1
Old Apr 12, 2017 | 04:47 PM
  #5545
HDMIKETN64's Avatar
HDMIKETN64
I built a Stage IV equipped 103 when I bought my 2015 Road Glide. It included the ported/polished heads and all the other goodies. It breathes through D & D Boss Fat Cat 2 into 1 exhaust. The dyno numbers for it were 115 HP/115 ft-lbs torque. Not bad for a 103, IMHO.
Tman 590 cams
SE 58 throttle body
SE 5.3 injectors
TTS tuner
crusher mufflers
Those are some damn good numbers.
Old Apr 13, 2017 | 09:24 AM
  #5546
ucbruce's Avatar
ucbruce
Originally Posted by Face84
Rhineharts 2 into 1
is this a Stage 1?
Originally Posted by Heatwave
My 2017 CVO Limited Stage IV with Fuelmoto Jackpot headpipe and SE Street Cannons. 128/128. Runs terrific EVERYWHERE. Not too bad for all Harley internal parts.
5th gear dyno
The Stage IV is a great kit...what a difference! Did wonders for my 2013 FLHTK with the 103"...torque curve isn't a curve at all, but a straight line of steady power. That's the biggest difference I see. Instead of of torque building like HP, the torque line jumps right up over 100, and stays there, all the way to 5500 RPM...that's what heads, cams, pistons and 58mm throttle body will do; give you a significant increase of torque across your power band...
Old Apr 13, 2017 | 10:26 AM
  #5547
sailmotion's Avatar
sailmotion
2014 Ultra Limited<br/>Stock exhaust<br/>Arlen Ness Big Sucker air cleaner<br/>Power Commander V
Old Apr 15, 2017 | 11:01 AM
  #5548
Flhrse5 Heiko's Avatar
Flhrse5 Heiko
Default Is this ok for a std Flhrse5 110 CVO?
This is not so much HP orientated mapped but for as much torque as possible. Its good for me but not the winner for performance enthusiasts. For me the most important objective is to gainas early as possible max values necause the max rpm I run is about 4000. All the best heiko
Old Apr 15, 2017 | 02:37 PM
  #5549
speedrat's Avatar
speedrat
4th Gear
2017 RGS Stage 3 114, FM 2-1-2 header, SE Ventilator, TBR slip-ons, TTS dyno tune, 5th gear run
Old Apr 20, 2017 | 09:43 AM
  #5550
Bafflingbs's Avatar
Bafflingbs
