DYNO Numbers for Baggers???
Old Feb 19, 2016 | 02:20 PM
  #5271
JMP671's Avatar
JMP671
5th Gear
2014 FLHTK
106CI w/ S&S internals
585EZ cams
stage 1 street port (local porter)
SE 58mm SE air intake
MGS TD
97.12 HP
112.47 TQ
Attached Thumbnails  DYNO Numbers for Baggers???-2014-flh-106-tc-stage-2-mgstd-585-cam.jpg
Old Feb 20, 2016 | 09:52 PM
  #5272
BLVN's Avatar
BLVN
Originally Posted by Jon_S412
I had my bike built by these guys back in September! Great people at this shop and will never over sell you! Best part it's only 10 mins from my house!
Mines going into them on the 13th of March. cant wait... hoping for 100s... They have been great so far. enjoy every convo I have with J
Old Feb 21, 2016 | 07:41 AM
  #5273
Tn.Heritage's Avatar
Tn.Heritage
Originally Posted by JMP671
2014 FLHTK
585EZ cams
MGS TD
97.12 HP
112.47 TQ
I really don't mean to critique your build and tune but seems very lazy down low, especially for a 106 with ported heads and a 58mm TB. I'd get myself another dyno tuner. Something just not right with your combo. There's more to be had there if you can find someone to pull it out !!!!
Old Feb 21, 2016 | 11:54 AM
  #5274
wedjim's Avatar
wedjim
Not intentionally ruffling feathers, but thinking out loud...
Dyno time and bagger just doesn't feel right to me. I've done plenty of mods over the years on my bikes, but never put one on the dyno.
I'd like to know what kind of gains some have had and if they feel the cost is well worth it?mhow hard is it on the bike?
Old Feb 21, 2016 | 12:49 PM
  #5275
Squiddoc72's Avatar
Squiddoc72
Stage III
Recently installed rinehart extreme true duals, SE extreme billet ventilator and SE pro tuners on my 15 RK. Dyno tune results HP 83.25 and torque 103.99. Slight bump in numbers from stock, now looking at other things for mor HP and torque.
Old Feb 21, 2016 | 03:24 PM
  #5276
C.H.L.'s Avatar
C.H.L.
My guess is it is a lot harder on the bike to run around for thousands of miles with a bad tune than a couple of hours on the dyno.... Just my thoughts
Old Feb 21, 2016 | 06:09 PM
  #5277
ntraindavefl's Avatar
ntraindavefl
110ci 2012 SG
Old Feb 21, 2016 | 09:52 PM
  #5278
JMP671's Avatar
JMP671
5th Gear
[QUOTE=Tn.Heritage;14865370]I really don't mean to critique your build and tune but seems very lazy down low, especially for a 106 with ported heads and a 58mm TB. I'd get myself another dyno tuner. Something just not right with your combo. There's more to be had there if you can find someone to pull it out !!!![/QUOTE
That's what my builder told me. It's really hard to find an experienced tuner that's good with PV most tuners near me are good with TTS. I was also told the pipes could very well be the weak link. The bike runs well for now and don't notice the torque drop and bike has good manners. I will be moving to Lansing Michigan in April and hope there are more tuners in that area. I really appreciate all the info and help I can get.
Old Feb 22, 2016 | 10:47 AM
  #5279
426power's Avatar
426power
Stage one air cleaner, Cat removed, Supertrapp Stout mufflers and HD Pro tuner. 84.3HP, 106 FT lbs. torque. Well worth the money to have a proper tune.
Old Feb 22, 2016 | 02:45 PM
  #5280
Beagletim's Avatar
Beagletim
Decided to dyno the bike after moving from the Seattle area to the Denver area. Figured with a 6000 foot change in elevation it might help the bike run a little better. Baseline numbers were 66HP at 5300RPM and 84TQ at 3200RPM. After dyno 78.5HP at 4900RPM and 101.9TQ at 3300RPM. Smoother throttle response and less decel pop. Will be interesting to see how it impacts the running temp. Not a bad return for a $300 investment.
