Exhaust leak?
Old May 27, 2008 | 08:45 AM
bucs012's Avatar
bucs012
Default Exhaust leak?
Something that my bike has been doing the past year......Up by the head where the pipe connects in, I get a PUFFevery once in a while. Example is when I start it and it might not fire the first time. I might get a puff of air like.....come from up there. Also, when I am sitting still and hit the throttle quick to rev the bike up. Sounds likeleak down at the head/pipeat the beginning of the rev. It's not a exhaust or engine rumbplt butlikea "puff" of air. I assume this is an exhaust leak? I have tightened the bolt down a few times but it it tight.
Is there a gasket up there that could be blown out? My bike is still under 2 year warranty.
Old May 27, 2008 | 09:16 AM
TexasRedneck's Avatar
TexasRedneck
Default RE: Exhaust leak?
Sure there is - right there at the header connection. With the engine COLD (unless you like toasted fingers), fire it up while feeling around the connection. If allowed to go long enough, the gasket will be "cut" by the exhaust gas, and require replacement. It's not uncommon for the flange nuts to loosen a bit. You can tighten 'em, but if it's under warranty I'd let them do it just to be sure that it's properly torqued (presuming you find 'em loose).
mke125125
Feb 4, 2010 02:23 PM
GymChamp
Nov 26, 2009 02:56 PM
kawsakimx6
Feb 9, 2008 03:50 PM
OldBoldPilot
Exhaust System Topics
Feb 20, 2007 07:14 PM
Sporty12C
Aug 31, 2006 06:51 PM
