Antenna delimma
Old May 28, 2008 | 11:25 AM
macsinbragg's Avatar
macsinbragg
Default Antenna delimma
I have a 08 RG and jsut recieved "all" the parts that I was supposed to form the dealer in order to put on the king toupak. Everytihng went well until the Antenna. I think I am missing a part or something because the old antenna cable doesn't seem to reach. Waht are my options? I have heard about a fariing mounted one. Is that an option as well?
Thanks,
Scott
Old May 28, 2008 | 11:30 AM
Johan96's Avatar
Johan96
Default RE: Antenna delimma
Is this the part You need?
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Old May 28, 2008 | 12:35 PM
Caulky's Avatar
Caulky
I had the same issue with my SG. It has plenty of cable you have to follow the cable and cut the zip ties off. Mine had one under the seat on the left side of the rear fender and one under the left side cover . Then you can pull enough cable out to make the connection to the tour pack and just put new zip ties back on.
I was told at the dealer because these bikes do not come with the tour pack they just pull enough out to make it to the antenna and coil up the rest and tie it off .
stroker87
Apr 26, 2018 01:05 PM
Henry89
May 28, 2014 10:16 PM
sinister1
May 20, 2013 08:19 PM
nukeman19
Apr 14, 2013 10:55 AM
bushski
Nov 20, 2007 10:31 PM
