bad front end wobble need help
Old May 29, 2008 | 05:18 PM
caspr2's Avatar
caspr2
Default RE: bad front end wobble need help
ORIGINAL: badstreetglide
I have an 08 street glide with 113" screaming eagle 131hp and 140tq had a wobble.Installed both braces the one that mounts from crossmember to trans pan and the shaft that goes threw the trans and swingarm but its still there only happenes at 90mph or higher what do you guys think?
WOW! That mtr workin good.
Check at low speeds you balance, 60 mph take your hands off the bars, does it want to go where its pointed?
Make sure the weight is even between bags, if you have a 2 into 1 load the left with enough weight to make up the differance.
Hope this helps.
Old May 29, 2008 | 05:49 PM
rsol's Avatar
rsol
6th Gear
The problem is in your arms moving the bars ever so slightly. With speed at 90 mph. you are probably placing a slight input on the bars that transfers through the shoulders and creates a wobble. Or you hit a slight bump that starts the wobble transition then your arms continue to translate the wobble.The next time you are on a straight level road with no bumps going 90 + ease up on the bars when it begins to wobble and you will notice that it will straighten itself out.
Old May 29, 2008 | 06:34 PM
milt50's Avatar
milt50
Stage IV
I had a similar problem with my RK classic.It turned out to be tires, took the metzler marathons off and went back to dunlops , problem solved!
Old May 31, 2008 | 12:37 AM
GMONEY220's Avatar
GMONEY220
caspr those numbers are comeing from a SE cam???If so your tuner new name is "THE WIZARD"
Man thats a pink slip snatcher!!!
kidn1980
Sep 1, 2016 03:03 PM
daman dabney
Jun 23, 2012 06:09 AM
LaRider
Wheels/Tires
Nov 20, 2010 06:36 PM
deathxgrip
Nov 1, 2009 02:48 PM
teamstersteward
EVO
Sep 28, 2009 02:33 AM
