bad front end wobble need help
Old May 28, 2008 | 07:01 PM
badstreetglide's Avatar
badstreetglide
1st Gear
Default bad front end wobble need help
I have an 08 street glide with 113" screaming eagle 131hp and 140tq had a wobble.Installed both braces the one that mounts from crossmember to trans pan and the shaft that goes threw the trans and swingarm but its still there only happenes at 90mph or higher what do you guys think?
Old May 28, 2008 | 07:30 PM
Kern's Avatar
Kern
Default RE: bad front end wobble need help
I think you need a Hayabusa to fulfill your high speed needs.
Save the Harley for cruising...... [8D]
Old May 28, 2008 | 07:57 PM
BM83's Avatar
BM83
I would check the fallaway. It's possible the neck bearings need adjusted. Also check the alignment of the rear wheel.
Old May 28, 2008 | 07:58 PM
BM83's Avatar
BM83
also check that the axles are properly torqued.
Old May 28, 2008 | 08:14 PM
Beemervet's Avatar
Beemervet
and tire pressure.
Old May 28, 2008 | 08:15 PM
badstreetglide
1st Gear
its only in the front endafter 90 mphthenthe handle bars wobble
Old May 28, 2008 | 08:16 PM
TXCHOP's Avatar
TXCHOP
Yuo dont have spokes do you?
Old May 28, 2008 | 10:12 PM
badstreetglide
1st Gear
no spokes aftermarket hd alloy wheels with a 200 on the rear
Old May 28, 2008 | 10:43 PM
DZLDR's Avatar
DZLDR
I'd try putting a dial indicator on your brake rotors and checking the run out on them. Turning the RPM's you are talking about, anything that is not almost perfect is going to be amplified at those speeds.
Old May 29, 2008 | 05:09 PM
badstreetglide
1st Gear
ill try it
