Upper Tins on front forks.
Old May 29, 2008 | 12:43 PM
tuna1's Avatar
tuna1
Default Upper Tins on front forks.
Just had some chrome lowers and upper tins put on at a shop recently and notice one of the tins are on backward with the seam facing out. The shop said to bring it back and they would change it. My question is can I just take out the two screws in the top of the upper tin and just pivot it 180 degrees or is there more to it than that? Any help is much appreciated. Thanks
Tuna
Old May 29, 2008 | 01:17 PM
04RoadKing's Avatar
04RoadKing
Default RE: Upper Tins on front forks.
First off WOW!!!!!!!You have got to be kidding me?????
How in the hell could that of been missed? That's pretty bad.....
I wouldn't ever go back to that shop again.
OK back to your question I don't think you can just undo the bolt without removing a lot of stuff. I know when I did mine on my Road King a few months ago I had to remove the headlight assembley. I would think on your bike you'd have to do the same. If I remember correct the front wheel, fender, and fork legs have to be removed also. Good luck...
Old May 29, 2008 | 02:17 PM
stro1965's Avatar
stro1965
If you can reach the 2 mounting screws, then YES, it should just spin around. I would think that the most you'd have to remove would be the outer fairing, passing lamps and the lower chrome piece directly behind the passing lamp bar.
lkr0
Oct 1, 2015 06:25 PM
FL-kruzen
Jan 14, 2012 07:51 AM
Bugsplat
Nov 17, 2010 01:30 PM
HGM
EVO
Jan 25, 2008 07:18 PM
Mike NY
Dec 25, 2007 02:15 AM
