103 kit
Old Jun 2, 2008 | 05:32 PM
osolow's Avatar
osolow
Default RE: 103 kit
well this is what i was told 2250 were for pipes and to have the bike sert tuned. the rest then the rest was for parts and labor.
a few parts i dont think should be replaced were cylinder studs. 200 to have the jugges bored and then he said clutch spring fluids and gaskets besides the major parts piston $200 cams $250 8 hr labor
i just called the dealership in
Alexandria, LA, and talked to chris which seemed like a cool guy he told me i could ride down there be there for a day and ride home the next day on a 103 for just under 18oo and some change.
Old Jun 2, 2008 | 05:56 PM
ripper43's Avatar
ripper43
Default RE: 103 kit
ORIGINAL: osolow
I suppose you have to supply your own KY with that. The HD kit comes with new Jugs and everything else you need for $1200.00 + labor 8 hours is more than enough. better shop around I would think.
Old Jun 2, 2008 | 06:15 PM
cardboard's Avatar
cardboard
Default RE: 103 kit
Is yer dealer doing a stage 1 or a stage 2 103 kit.
Old Jun 2, 2008 | 06:19 PM
Jim Dawson's Avatar
Jim Dawson
Default RE: 103 kit
I had the dealer do the 103" stage II kit during a winter special and it was about $1600.
Old Jun 2, 2008 | 06:23 PM
cardboard's Avatar
cardboard
Default RE: 103 kit
ORIGINAL: Jim Dawson
Jugs and pistons only hug !
PFD232's Avatar
PFD232
Default RE: 103 kit
I had 103 big bore, Rinehart True Duals, They wired in my Hawg Wired double shot sound system and installed a LED light under feul tanks, diamond cut the heads all this for 3700$$$
Old Jun 2, 2008 | 06:26 PM
cardboard's Avatar
cardboard
Default RE: 103 kit
The dealer does a parts build, and it will not stay with a Indy build.
Old Jun 2, 2008 | 06:28 PM
TexasRedneck's Avatar
TexasRedneck
Default RE: 103 kit
Wahl, ah reckon ah ain't doin' too bad then.....fixin' ta have mine upgraded w/the 110" kit - lookin' at 'bout 3900, parts an' labor....
Osolow....a li'l more profile info would make it a LOT easier fer folks ta help ya w/info - both now an' future!
Old Jun 2, 2008 | 06:30 PM
Jim Dawson's Avatar
Jim Dawson
Default RE: 103 kit
ORIGINAL: cardboard
It also included SE 255 cams.
Old Jun 2, 2008 | 06:32 PM
cardboard's Avatar
cardboard
Default RE: 103 kit
ORIGINAL: TexasRedneck
5000.00 for the 110 build. It makes about 85hp. But won't outrun much.
