I just recently installed some Wild Pigs slip-ons on my 03 road king classic and I am noticing some rattling noises coming from the pipes. More on the left side than the right. But I believe it is the baffle viberating inside the muffler. It came with the standard 1 3/4" baffels in them. What can I do to make it stop ratteling? You cannot notice it all the time but when you do, it sounds horrible. Thanks.
Pound muff with palm to see if it rattles....if it does, pull baff and distort the front diameter(egg-shape it) \\;until it is hard to insert....insert baff and tighten screw...problem solved.
Pound muff with palm to see if it rattles....if it does, pull baff and distort the front diameter(egg-shape it) \\;\\\\\\;until it is hard to insert....insert baff and tighten screw...problem solved.
I've done that a couple of times but she made more of a \\;moan than a rattle. \\;
