Considering Xied - nightrider
Thanks, CDN. RG.
Glens, in layman's language, what are the possible downsides to these IEDS.
I know I'm not the sharpest knife in the draw, but I'm not getting it.
No disrespect intended.
I guess I do not know how to layman up the language any more than I have but will try.
Whenever the ECU has to add or subtract fuel to reach its target O2 voltage while in closed loop, it stores that difference, from the amount of fuel it thought it should have sent, as a factor for figuring future fuel amounts. It will use that factor everywhere, even in open-loop modes, because normally that would be the correct thing to do. (If you are consistently rich because your air filter is dirty, or if you are consistently lean because you bought a tank of oxygenated fuel, the condition as measured during closed loop would certainly be present by the same amount even when the ECU cannot sample the combustion.) This factor is referred to as the AFV.
In another recent thread where a guy asked about trying some older Screaming Eagle mufflers I covered a lot of this stuff in very simple language. It was a couple of days ago. Here.
With these devices in place, the ECU will have to factor in more fuel because its target O2 voltage is now the result of the devices and not that of the O2 sensors. This more fuel is what makes for better driveability and cooler running for the bulk of the time you are cruising around. Whenever you are using the engine in modes where the ECU programming was already rich-enough (and those areas certainly do exist, even on a completely stock bike) it will there/then become too rich. Possibly acceptably too rich, though still ideally too much, when using the standard devices. Likely way too rich when using the extreme ones.
And like I have said many times already, the extreme IEDs do not leave enough wiggle room within the sensor operational range. Look at a graph of a sensor output. So long as it is operating anywhere in the steeper middle range, where a moderate change in air/fuel ratio results in a moderate voltage change, it will be fine. Once it gets to the flatter part of the curve at either end, a very small difference in output voltage covers a wider and wider range of air-to-fuel ratios. At the edge of the curve, a tiny difference in voltage can cover a range from mildly rich to stupidly rich.
The standard IEDs still leave reasonable wiggle room within the sensor output curve. The extremes flat out flirt too heavily with the edges.
Once the limits of the AFV correction (extra fuel) have been reached, the computer throws an your cylinder is running too lean warning code. Remember what I just said about the sensor operating in and out of its linear range. A couple percent difference in fuel might show as a couple millivolts in the middle, but at the edges of the sensor range a couple millivolts might easily represent/require double digits of percentage change in fuel.
CNC Wheel Guy ,I can't recall what the numbers were without the xieds becuse he must of did about 20 pulls with the bike using different configurations and part throttle runs,I do remember the afr was about 15to 1 without them in closed loop.
So Glens, in your opinion what is the best value for improving performance on the 08's?
I have not really shopped around lately but would have to wonder why the Fuelmoto package is not consistently back-ordered (maybe it is?). It is essentially what I have assembled on my 07 (I have Rush 2-inch baffles on stock pipes, K/N breather assembly, and PC-III). What is it, like 800 bucks to your door? It is a solid package that works very well and looks/sounds as good as it works.
What I think I would like to end up with some day is the Daytona Twin-Tech EMS and the Bub 7 duals w/crossover. Got to get un-unemployed first, though.
Love this thread! Seriously. I don't quite understand it, but like many of us that have changed the air filtern and pipes want to know what would be best for the engine if no EPA was involved! Additional questions...how does the V&H FuelPak improve the equation? Is it enough? BTW, stock engine, SE air-clearner and V&H ovals.
Wide-band sensors are more complicated and costly in and of themselves, and on top of that, they require control circuitry, and their native output is quite different from narrow-band sensors. There are replacement wide-band sensors available that come with controllers which can be set to output the same type of signal as the ones in our engines. The setpoint is variable, so you could dial in whatever AFR you wanted. But the caveat is our stock EMS and the way it auto-tunes.
I am sure that if H-D had anything to say about it, the bikes would be running quite differently right from the factory. They have done a damned good job considering how tightly their hands are tied.
