ultr classic
Old Jun 26, 2008 | 07:56 AM
FLHT's Avatar
FLHT
Default RE: ultr classic
ORIGINAL: Guitars1
OK now that is some good info right there, I am not even sure if I ned to make it switch from the faring I could just soilder it in line from the battery to the surius and it should work right?
You could do that too. But I will tell you right now its going to be a lot simpler if you pull the front of the fairing and do your wiring in there. You can pick up a switched positive in there that will power down your radio when you turn off your switch.
hrchdog
2014-2024 Touring Models
Jul 19, 2015 02:23 AM
Ron C
Electrical/Lighting/Alarm
May 12, 2015 09:39 PM
mwriggs
Dec 14, 2009 07:38 PM
slickscustoms
Sep 26, 2009 02:47 AM
yodal
Aug 2, 2006 07:59 PM
