performance heads???
Old Jun 27, 2008 | 03:06 PM
eglinski's Avatar
eglinski
Default RE: performance heads???
HDUC,&nbsp\\; How much was that 98ci&nbsp\\; GMR kit?? &nbsp\\;&nbsp\\; Did you pay to have the work done as well?
Old Jun 27, 2008 | 03:36 PM
bowsharleys's Avatar
bowsharleys
T-Man in North Carolina makes some really good heads. I am sure they are priced about the same or maybe higher than Head-Quarters. http://www.tmanperformance.com/
Old Jun 27, 2008 | 04:35 PM
blueflht's Avatar
blueflht
heres my .02 worth.&nbsp\\; i would try a revolution performance 98" kit jugs and pistons for 1100$ then send the original head to big boys in me. for a port and polish head job for 299$ add cams for about 345$ and keep the lift to 510. compression will be at about 9.5 to 1 runs on pump gas and you will see stump pulling torque in the 110 ft/lbs area and 98 to 101 hp!
Old Jun 27, 2008 | 06:48 PM
mrbuck's Avatar
mrbuck
thanks i thnk now i just confussed i guess its best to talk with someone who really knows like HQ then go from there
Old Jun 28, 2008 | 10:18 AM
wydopn231's Avatar
wydopn231
Tman performance in Kernsville NC is damn good on heads.Over look some of his personality trates.hes damn good on heads and combos for harleys.He had 155 ci tc making 214 hp at daytona shootout few years back,thats at the wheel and without boosters
Old Jun 28, 2008 | 12:14 PM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
I'm so confused[sm=confused06.gif]
Old Jun 28, 2008 | 02:34 PM
mrbuck's Avatar
mrbuck
harleypingman what kind of setup are you running i like the ideal of staying w/88"but would like more tourqe to come of the line a little faster? top speed is not that important as long as i can still pass at 80 or 90 mph
Old Jun 28, 2008 | 02:36 PM
mrbuck's Avatar
mrbuck
philm saw that you and the rest of the gang made it onto HQ's frontpagewith the power tour '08 congrats...so what kind of coin am i lookin at at HQ a sport touring 98" with cam, lifter comp release is like $2400 with no labor to install? what install on something like this? 1500?? whos done one and what'd it cost total w/ dyno and ridin down the road happy&nbsp\\;
Old Jun 30, 2008 | 07:25 AM
hduc2005's Avatar
hduc2005
ORIGINAL: eglinski
HDUC,&nbsp\\;\\\\\\; How much was that 98ci&nbsp\\;\\\\\\; GMR kit?? &nbsp\\;\\\\\\;&nbsp\\;\\\\\\; Did you pay to have the work done as well?
I did the work myself as for cost here is all that I got....
blk 98 inch kit with 3 CC CP forged pistons
Stage III CNC Heads 1.9 intake valves, 1.625 ex
Andrews Gear drive install kit Gear drive install kit
525/525 cam custom ground 525 cam for 88-96 inch engines
Andrews four gear set Inner and outer gear drive kit for 99-06
Top end gakset kit Cometic EST top end gasket kit .030 head gasket
Pushrod covers
Chrome/moly push rods 4130 chomemoly pushrods
Compression Release Compression release 10mm
compression to 10.1.1
D&amp\\;D Fat cat pipe fat cat 2-1 pipe
with quiet baffle
right around $3000
Rings were on the pistons and marked for front and rear and marked for location
masterblaster
Jul 9, 2008 10:57 PM
slack20
Jul 2, 2008 09:20 PM
Ultra61
Jun 29, 2008 02:29 PM
damadman
Jun 19, 2008 07:10 AM
wydopn231
Exhaust System Topics
Jun 18, 2008 11:17 PM
