Tranny sprocket noise
Old Jun 28, 2008 | 10:22 PM
dgretz's Avatar
dgretz
Default Tranny sprocket noise
When I push the bike backwards I get a clicking noise coming from the transmission sprocket area.&nbsp\\;What might it be as it only started recently?&nbsp\\;I checked the drive belt and it appears okay and adjusted correctly.
Old Jul 16, 2008 | 11:43 PM
dgretz's Avatar
dgretz
Default RE: Tranny sprocket noise
Took it to the stealership two weeks ago and first response from tech was belt to tight/loose.&nbsp\\; Said no way checked that already.&nbsp\\; Got him to put on rack to check and low and behold said it wasn't belt could be inner primary bearing or tranny bearing as he has seen a few of these lately.&nbsp\\; Service was booked till 2nd week of August.&nbsp\\; Was able though to get in last Tuesday.&nbsp\\; They did not start on it till Sat.&nbsp\\; and then could not get the noise to happen.&nbsp\\; Found out they did not get it hot so they ran it and the noise appeared.&nbsp\\; Now waiting for parts to replace the&nbsp\\;inner primary bearing and&nbsp\\;transmission bearings.&nbsp\\;
Old Jul 30, 2008 | 11:30 PM
dgretz's Avatar
dgretz
FYI
&nbsp\\;
Those interested or hear a clicking noise from primary area when pushing bike backwards.&nbsp\\; They replace the main drive gear needle bearings (one was scored) and the primary bearings (nothing found wrong with them) and all is fine now
Old Jul 31, 2008 | 05:18 AM
rickoshay45's Avatar
rickoshay45
I had the same thing happen. On mine they changed out all the bearings and the output shaft.&nbsp\\;I had heard the ticking but only once or twice, what tipped the wrench off was the metal shavings on the drain plug.
Old Aug 15, 2008 | 05:39 PM
Rain's Avatar
Rain
Same thing for me on 2000 RK last fall.
Old Aug 17, 2008 | 02:22 PM
acedantinne's Avatar
acedantinne
Originally Posted by dgretz
FYI
&nbsp\\;
We would like to know the cause? Lack of oil? A bearing rides in and on something? What other parts needed to be replaced?
Thanks for your answers, ACE
toecat2000
2014-2024 Touring Models
24
Jul 31, 2017 08:39 PM
SummitRK
Aug 16, 2016 03:19 PM
66impala
Apr 19, 2015 04:02 PM
o/d
Jan 29, 2014 07:02 PM
fll
Engine Mechanical Topics
Oct 7, 2013 09:44 PM
