Broken fairing air deflector
Old Jul 5, 2008 | 08:32 AM
Kroozer's Avatar
Kroozer
Default Broken fairing air deflector
Coming home from a ride, yesterday, I noticed that the right fairing air deflector (08 Ultra) was loose. Upon closer examination, i discovered that the top hinge part broke off the deflector, and was just barely holding on. Once I moved it, it broke off copletely. I have no clue what might have caused it. I do not even move the vents too much. I had them in the closed position, when it was cooler, and I opened them when the weather warmed up. I thought they felt a bit too stiff, but I thought that's how they're supposed to be. Now i have the deflector taped to the remainig hinge pin, with black electrical tape. Looks like crap, but at least it doesn't flop around. Another part, probably made in the mighty Republic of comunist China! Sheesh!
Old Jul 5, 2008 | 09:42 AM
Garemlin's Avatar
Garemlin
Default RE: Broken fairing air deflector
I've seen a few people post about the 08 deflectors breaking. I was gonna add them to my 08 SG but not if they are that damn flimsy. Guess I'll either wait for a revision part or go with another company.
Old Jul 5, 2008 | 11:26 AM
ctmedic's Avatar
ctmedic
I would change them to freedomwings or dragon wings (close to the 08 style) I dont know if they make them for the 08s yet as they use a 4 screw system on the 08s
&nbsp\\;
Frank
Old Jul 5, 2008 | 11:32 AM
Richpend's Avatar
Richpend
I have wondered about that, if they will ever work there way loose or not, mine is to new still...hopefully they will stay in strong
Old Jul 5, 2008 | 11:36 AM
bikergeoff's Avatar
bikergeoff
So what we have learned is that the MoCo's 4-bolt system sucks as bad as the 3-bolt on the earlier models. Luckily I found a local guy who makes custom air deflectors that hold up better than the factory's. If anyone's interested, PM me and I'll forward his info.
Old Jul 5, 2008 | 12:20 PM
stro1965's Avatar
stro1965
Uh oh, I just installed the new '08 style on my bike a few weeks ago, hafta keep an eye on them!
&nbsp\\;
Old Jul 5, 2008 | 01:23 PM
MNPGRider's Avatar
MNPGRider
Freedom Wings first models broke on the top mount, in the screw hole into the fairing. The mount did not screw down flat due to the shape of the fairing. The new ones come with a rubber cushion washer to absorb vibes better and take up the gap.
&nbsp\\;
They will send a free retrofit kit if you have one break, as I did.&nbsp\\; Otherwise, just pick up a couple of faucett washers and install under the upper mount.
Old Aug 31, 2008 | 02:30 PM
fedexway's Avatar
fedexway
2nd Gear
Got 1500 miles on my Ultra and stoped to get gas Sat. looked down and the vent was hanging out from the fairing. The top hing was broke so I looked at the other side and the hing has not broke yet but the vent itself is cracked in front of the hing. Stopped by the dealer and talked to them about it and he gives me this funny look saying he has never seen them do this. Anyway they have to order them and give me call when they come in but sounds like this problem may not go away with there stock vent.
Old Aug 31, 2008 | 08:53 PM
Jim Dawson's Avatar
Jim Dawson
My right hinge broke after 5,000 miles. I ordered a replacement for around $25.00. If, as I did, you added it as an accessory, they don't offer a replacement. Since they are standard on the Ultra, it is available as a replacement Ultra part.
It is funny that the kit of two deflectors from the accessory catalog is about $100, but a replacement deflector for an Ultra is $26.00.
OdieHD
General Topics/Tech Tips
Sep 25, 2009 02:33 PM
peddler
Oct 9, 2008 09:36 AM
captjon37
Sep 23, 2008 03:39 PM
mdtpr
Jan 16, 2008 08:25 AM
bmwbutch
Aug 28, 2007 04:23 PM
