IDS on 07 Touring Bikes
Old Jul 8, 2008 | 07:10 AM
nvsteve's Avatar
nvsteve
Default IDS on 07 Touring Bikes
Just about ready for a new tire so considering adding the IDS kit.
I have none of the whining or rattleling. Any of you had NONE of the symptoms and still added the IDS?&nbsp\\; If so, what were the results?
07 Ultra- 8000 miles
Old Jul 8, 2008 | 07:25 AM
Phurion's Avatar
Phurion
Default RE: IDS on 07 Touring Bikes
I never really had the "5th gear whine" I kept reading about, but I did notice some clunkiness when shifting gears. Not bad, but it was still annoying. Added the IDS on the Elbow Grease program when I had a store credit, so it cost me next to nothing to do.
FWIW, I'd do it again. Smooths out shifting considerably. I also never lugged my engine below 2000 RPM (which is what a lot of folks claim was the moco's motivation for coming up with it...hawgwash I say! Pun intended =) Other mfr's have been using similar systems for years for a number of reasons. HD finally caught up with the rest of the crowd.
If you have the $$ I'd recommend it.
Old Jul 8, 2008 | 07:35 AM
robandlyn's Avatar
robandlyn
"If you have the $$ I'd recommend it."
&nbsp\\;
I'll second that !
Old Jul 8, 2008 | 07:42 AM
whoop72's Avatar
whoop72
If I had NO symptoms, I wouldn't waste the dollars.&nbsp\\; Doesn't seem to make sense to me.
Old Jul 8, 2008 | 07:47 AM
Sheep's Avatar
Sheep
ORIGINAL: Phurion
&nbsp\\;
I&nbsp\\;didn't really have the 5th gear whine that others experianced.&nbsp\\; But I did install the IDS under the "Elbow Grease" program also.&nbsp\\; So wasn't that expensive to do.&nbsp\\; There's a difference but not a huge noticeable difference.&nbsp\\; That said HD did make it standard starting with the 2008 models so evidently they thought it worthwhile.
Old Jul 8, 2008 | 08:11 AM
poppa cooter's Avatar
poppa cooter
i have ids, glad i did it for a couple of reasons it makes sense for prolonging the drive train, i use my rear brake alot for slow manuevering, it helps to steady the bike for those rolling stops too lol. and i think the ids will help to keep some of the pressure off the drive train, not all of the pressure but some of it.
Old Jul 8, 2008 | 08:16 AM
stro1965's Avatar
stro1965
ORIGINAL: whoop72
If I had NO symptoms, I wouldn't waste the dollars.&nbsp\\;\\\\\\; Doesn't seem to make sense to me.
&nbsp\\;
I second that.&nbsp\\; I installed it to quiet 5th gear clatter, other than that I see no real reason for it.
&nbsp\\;
Old Jul 8, 2008 | 08:18 AM
alqaadir's Avatar
alqaadir
Old Jul 8, 2008 | 08:20 AM
NICK56's Avatar
NICK56
RIDDEN MANY&nbsp\\; MCY'S OVER MANY YEARS&nbsp\\; ... 37.&nbsp\\; &nbsp\\; MY OPINION...
&nbsp\\;
FOR THOSE WHO HAVE NOT INSTALLED THE IDS ON UR&nbsp\\;\\\\\\; 07'S...YOU&nbsp\\;\\\\\\; DONT KNOW&nbsp\\;\\\\\\; WHAT YOU'RE MISSING.&nbsp\\;\\\\\\; THE IDS WILL&nbsp\\;\\\\\\; MAKE IT SEEM LIKE YOU ARE RIDING A DIFFERENT MACHINE.&nbsp\\;\\\\\\; IF U HAVE THE $210.00&nbsp\\;\\\\\\; (WWW.DISCOUNTBIKER.COM)&nbsp\\;\\\\\\; JUST BUY IT... ITS THE MOCO'S MISTAKE..&nbsp\\;\\\\\\; WHY DO U THINK THE 08'S&nbsp\\;\\\\\\; AND UP WILL ALL HAVE THE IDS.. THE O7'S WERE&nbsp\\;\\\\\\; THE MOCO'S .. BOO BOO!
THE CORRECTION&nbsp\\;\\\\\\; WAS THE IDS!
MY 2 CENTS.
&nbsp\\;\\\\\\;
Old Jul 8, 2008 | 08:28 AM
Hog Yild's Avatar
Hog Yild
I installed the IDS, it's a simple task if you have ever changed a rear tire before. I would recommend having the dealer install the bearing unless you have a press and a sleeve to install it correctly. Otherwise you can damage the bearing and end up with short bearing life. I think it just helps a great bike become that much better.&nbsp\\;
