compensator nut
Old Jul 10, 2008 | 04:36 PM
choptop's Avatar
choptop
Default compensator nut
have .090 side to side movement on shaft, thought maybe I needed to shim it, found last 10 or so threads in nut were full of locktite and nut was not going in all the way, per manual used straight edge and sprockets line up.&nbsp\\;&nbsp\\;&nbsp\\; My question is, when I put nut pack on and toeque it down, 150#, should everything be snugged together, nut/retainer/sliding cam/ compensator or is a little side to side acceptable&nbsp\\;?&nbsp\\; Thanks
Old Jul 10, 2008 | 04:39 PM
miacycles's Avatar
miacycles
Default RE: compensator nut
A little side to side is OK !!!!!!!!
Old Jul 10, 2008 | 08:24 PM
choptop's Avatar
choptop
Thanks John
Old Jul 10, 2008 | 08:28 PM
choptop's Avatar
choptop
I have cleaned the threads but the nut seems to bottom out befor it tightens things up, probably a good .060 side to side, this is on a '90 fltc, I have read a lot of threads on the compensator nut, one thread talked about milling some off the screw end of the nut so as to tighten it up to specs, sounds feasable to me. Anyone, anyone
dubepj
EVO
13
Jan 29, 2019 03:56 PM
falconbrother
EVO
Feb 11, 2014 01:14 AM
TUCCI
Feb 28, 2012 08:21 AM
notarheli
Exhaust System Topics
Jun 8, 2008 12:58 PM
rleggs
Mar 9, 2007 09:14 PM
