High Idle Reflash Fix Does not work!
Old Jul 10, 2008 | 09:21 PM
Mathews2's Avatar
Mathews2
Default RE: High Idle Reflash Fix Does not work!
I think he has every right to expect his 20k bike to function properly.&nbsp\\; And the just let it idle down so it will function properly arguement is pretty lame.
Old Jul 10, 2008 | 09:27 PM
papifun's Avatar
papifun
got mine reprogramed on June 17th..., no problems yet...settles at 1000rpm when engin warm no erratic RPM noticed - when cold starts at about 1300-1500 rom and then drops off slowly in about 2 min..
Trock's Avatar
Trock
No lame is killing it at 2000 rpm's
Old Jul 10, 2008 | 09:34 PM
Mathews2's Avatar
Mathews2
I guess it is also lame to expect it to function as it should
Old Jul 10, 2008 | 09:39 PM
Trock's Avatar
Trock
No but this conversation is
Old Jul 10, 2008 | 09:42 PM
Mathews2's Avatar
Mathews2
Old Jul 10, 2008 | 09:46 PM
tmac's Avatar
tmac
It's not just if you shut down at high idle, my RK has had the issue after 80 miles when I stopped for a red light. Had the reflash done today w/ the 1000 mile service, don't know if it worked yet. BUT, I also had new grips installed today and now the cruise control doesn't work. Awesome. Now I get to go back tomorrow. Are you friggin kidding me? Sorry for the bitch, I still love the bike.
Old Jul 10, 2008 | 09:53 PM
uweldit's Avatar
uweldit
IMHO, this&nbsp\\;is a Delphi issue, Harley has it's hands tied until they come up with a fix.
Old Jul 10, 2008 | 09:56 PM
bdp's Avatar
bdp
You do know about cycling the ignition switch three times to get idle back to normal.
&nbsp\\;
I've learned to remove my hand from the grip before killing, or at least verify 1000 rpm before hitting the switch.
Old Jul 10, 2008 | 09:59 PM
Raiderse's Avatar
Raiderse
Point being that H-D acknowledged the problem. Had an entire model year to correct it and then the fix fails. There is no need for this with Throttle By Wire. Yamaha hass been doing it for years , GM has been doing it for years and the high idel problem does not exist on their vehicles. Why does the ECM need to remember the last idel speed when theignition&nbsp\\; was shut off?
