FUEL FILTER CANISTER
Old Jul 10, 2008 | 08:40 PM
RAMP27's Avatar
RAMP27
6th Gear
Default FUEL FILTER CANISTER
As a dealer tech, I have changed a lot of fuel filter canisters. I own a 08 FLHTCU and am going on a 2500 mile vacation next week. As a precation, I thought I'd go ahead and change the canister to the -08a part number. My bike's got a build date of 10/07 so I figured it must have the old canister. I checked the replaced warranty ones against a new one so I'd know exactly what was different. Guess what. After removing the top plate assembly, I was able to see that the installed canister is the new one. I hadn't been keeping track at work on what the build dates were of the one's I had replaced, but now I'm curious. If you're fuel canister has gone bad, look for the build date on the VIN label (left side frame neck area) And post it. It might bring some piece of mind and save some people some money.
Old Jul 10, 2008 | 08:47 PM
dgoodbmw's Avatar
dgoodbmw
Default RE: FUEL FILTER CANISTER
Build date 08/07. Canister replaced at 5500 miles, broken catch.
Old Jul 10, 2008 | 08:55 PM
TexasVet's Avatar
TexasVet
Mine also has a build date of 10/07.&nbsp\\; I went to change my fuel filter canister and discovered that it was the upgraded 08A part number.
ORIGINAL: RAMP27
Old Jul 10, 2008 | 08:58 PM
Trock's Avatar
Trock
I just changed mine a few minutes ago. Not a lot of difference in the old and new. In the reg. hole it looks different and a little beefier around the tabs. By the way I ordered mine on friday and it came today. Now there on back order again. Mine was built oct.07
Old Jul 10, 2008 | 09:08 PM
rick's Avatar
rick
My mfg date is 05/08 i take it i have the new one and should not have any problems down the road?
Old Jul 10, 2008 | 09:35 PM
Trock's Avatar
Trock
Well you have the new one. I hope they are better!
Old Jul 10, 2008 | 09:54 PM
roadkingsaddlebrooke's Avatar
Build date 10/07 and failed at 4200 miles.&nbsp\\; Replaced under warranty.
&nbsp\\;
Old Jul 10, 2008 | 11:27 PM
socalmoe's Avatar
socalmoe
What's the p/n for cannister?
Old Jul 11, 2008 | 12:39 AM
dawg's Avatar
dawg
ORIGINAL: socalmoe
&nbsp\\;
62229-08A
Old Jul 11, 2008 | 12:45 AM
Truman's Avatar
Truman
8/07 build...replaced mine today at 5100 miles, it showed signs of an imminent failure with stress marks around the edges of the tabs, feeling better with the updated part even though it only looks slightly better than the one I removed, only time will tell.
