Cruise turns on, won't set...?
Old Jul 12, 2008 | 05:47 PM
watercop's Avatar
watercop
Default Cruise turns on, won't set...?
My 06 RKC has 8K miles.&nbsp\\; My set/resume button quiet functioning today.&nbsp\\; The left side button will turn the cruise on (the red light comes on on the speedo)&nbsp\\; I think Ive checked the obvious, break lever play, throttle adjustment, brake light is going out, fring on brake lever is not pulling the brake lever back, havent washed the bike in a few weeks and cruise has worked fine since last washing.
Any other obvious things to be checked before pulling my pants down at the dealer?
&nbsp\\;
Thanks
&nbsp\\;
Watercop
2006 RKC
Old Jul 12, 2008 | 06:49 PM
Harleypingman's Avatar
Harleypingman
Default RE: Cruise turns on, won't set...?
IIRC, try disconnecing the two wires from the connector that is located just forward of the gas tank near the steering neck.&nbsp\\; IIRC, that's the wiring for the throttle position sensor.&nbsp\\; After the wires are disconnected, see if the cruise will "set."&nbsp\\; If it does, the TPS is bad.&nbsp\\; The TPS allows the cruise to disengage when you roll off the throttle.
&nbsp\\;
There is also a detailed diagnostic description in your service manual that is also duplicated in the DIY Forum.
Old Jul 12, 2008 | 07:08 PM
watercop's Avatar
watercop
Thanks...I'll look at that....I assume that the fuse is ok since the cruise will turn on.
&nbsp\\;
Watercop
Old Jul 12, 2008 | 08:41 PM
pscheval's Avatar
pscheval
I had the same problem last month, mine was still under warranty. It was the cable was broken at the top. you couln't tell unless you took it apart.
Old Jul 13, 2008 | 04:33 PM
dcfatboy's Avatar
dcfatboy
My problem was that I had re-shaped the CC module terminals during my probing of the module during the maintenance intervals.&nbsp\\; They had been re-shaped over time so that there apparently was not adequate connectivity to the CC module.&nbsp\\; I took a pick and re-shaped the terminals to what they should be.&nbsp\\; Works now.
Old Jul 13, 2008 | 09:52 PM
glens's Avatar
glens
Mine quit working the other day. I miss it. One of these days I will have to spend the time for a trip to the dealer.
It is definitely the RH switch itself malfunctioning. I checked two ways electrically.
Old Jul 14, 2008 | 07:32 PM
Noble Steed's Avatar
Noble Steed
The throttle roll off switch is probably broken. It is on the right side just in front of the gas tank on the idle cable under the rubber cover. Unplug the front spade plug on the switch and you should be back in business. Mine did the same thing. Good luck.
Old Jul 14, 2008 | 08:17 PM
glens's Avatar
glens
If you are talking to me, nope. I checked that. It functions perfectly.
From the common wire to each separate lead, disconnected at the cruise module, I get perfect momentary closure of both switch positions. The forward position goes higher than the resistance range of my Fluke (open). The rearward position (the set) mostly opens to various resistances, depending how I flick the switch without disturbing any other part of the bike. Should go full-open electrically every time, not 1/100.
Rickv8z
Sep 11, 2012 03:11 PM
Chas63
Jul 6, 2011 04:55 PM
Oil City Outlaw
Jul 4, 2011 09:26 PM
panhead12004
Jun 12, 2008 06:52 PM
panhead12004
Jun 9, 2008 06:55 PM
