Harmon Kardon Radio Problems
Old Sep 3, 2010 | 11:45 PM
  #91
roadgliderick's Avatar
roadgliderick
like someone stated earlier the H/K radio sucks i had a 2009 SG and had 3 radios replaced. until i bought a alpine cda 105 with the biketronics retro kit and all my problems are gone. harley should sell the bikes with out radios so u can pick and install your own.
Old Sep 4, 2010 | 11:03 AM
  #92
RDGLDR's Avatar
RDGLDR
6th Gear
Originally Posted by RDGLDR
My radio shut itself off once about three months ago , thought nothing of it.
Yesterday on the way home from the JOB it shut off than came back on, off again until i got home. looked for a short or pinched wire since i had adjusted the handle bars, found nothing. Went to get on it this morning to go to work and the radio is fine. But wait just before I get to work there it goes off, than back on and stayed on until I shut it off. Got on it to come home Working fine ..cruising listening to tunes watching for cagers being stupid. Pulled up to a stop light ... it shuts off... been home for about 2 hours cant get it to come back on. NOT a pinched wire it sounds like after reading this thread its a common problem and i'm going with out a radio for a while cuz in this economy I dont have 250.00 to have it fixed
OK it may not be the radio itself.
I couldn't stand it and went out this am to investigate a little deeper.
With the bike on and presumably the stereo also I started my removing the hand controls as i had recently adjusted the handle bars. I removed the right side and of course nothing changed... but as i loosened the left (clutch) side the radio came on. I finished removing the controls and found the wrapping around the harness was pinched a little and of course in the pinch was ONE wire. I adjusted the wire and taped the harness into a little tighter bundle and reinstalled it. SO its working for now and i will see after riding it for a few days to see if the problem returns.
ADVICE>>>> as previously stated it the problem in most cases can be directly related to the LAST thing you did.
Old Sep 11, 2010 | 11:24 PM
  #93
twilliams@midwestmail.com's Avatar
Stage I
I had exactly the same problem.....replaced the audio switch but it made no different. Still trying to run down the problem.
Old Sep 12, 2010 | 07:39 AM
  #94
1flhtk4me's Avatar
1flhtk4me
In my case the last thing i did was install an amp,no bar change.
Mine shut of yesterday once which is the norm.
Maybe I'll be lucky and the display will quit so I can get another radio under warranty to see if the sound problem still exsists.
Old Sep 12, 2010 | 04:18 PM
  #95
awood43's Avatar
awood43
Stage I
Default no sound from hk audio system
I'm looking for advise how to proceed when the sound from the hk audio (radio and mp3) of my sg2006 suddenly ceased. The self diagnosting does not indicate anything wrong!
Old Oct 5, 2010 | 04:20 AM
  #96
WannaBuy's Avatar
WannaBuy
The Harmon Kardon on my 2009 Ultra worked flawlessly for 28,000 miles and then while on a ride about three weeks ago the audio cut out. I have to power the unit down, wait a short time, then turn it back on and SOMETIMES the audio resumes. When it does it can last anywhere from several seconds to several minutes. The interesting thing is that I can play the radio all day long when it's parked in my garage on the accessory setting which leads me to believe that the HK isn't built to withstand the vibrations of the motorcycle. Gonna take it in once the weather turns and have it checked out since it's still under warranty.
Old Oct 5, 2010 | 11:32 AM
  #97
dougbk's Avatar
dougbk
If you need them fixed out of warranty I recommend Iron Cross Audio. Good work fast turn around.
Old Oct 5, 2010 | 12:01 PM
  #98
shortride's Avatar
shortride
Mine has been working fine until this morning. My XM radio is loosing it's mind. I mean memory. After pre-setting favorite satellite radio channels and turning the radio off and back on, it will always only go to channel 1.
Old May 22, 2011 | 01:10 PM
  #99
eric k's Avatar
eric k
Stage II
Red face amps
does any one know what the amps out to the speakers are for a stock 2010 street glide harmon kardon audio system
Old May 22, 2011 | 01:41 PM
  #100
cheeba greenleaf's Avatar
cheeba greenleaf
Stage II
i noticed recently that hd is offering a free upgrade to the harmon kardon radio system..its upgrade is now at version 8.25 not sure it this will help but i was wondering myself what does the upgrade correct???
