REAR SHOCK PUMP PROBLEM
Old Jul 16, 2008 | 07:08 PM
Dax4800's Avatar
Dax4800
Default REAR SHOCK PUMP PROBLEM
I was going to put some more air in my rear shock using my HD pump.&nbsp\\; When I screwed it on, it showed me the reading (16 psi).&nbsp\\;&nbsp\\;When I went to&nbsp\\;pump the shock up, the needle just shot forward to&nbsp\\;the end bar.&nbsp\\; I unscrewed&nbsp\\;then rescrewed on the pump and am getting no reading what so ever.&nbsp\\; I tried unscrewing and screwing it on two more times with the same result.&nbsp\\; Has this happened to anyone?&nbsp\\; Hopefully someone can help me out.&nbsp\\; I'm leaving on a 6 day trip tomorrow and just want to make sure it is the pump and not the shock.&nbsp\\; I'd really appreciate the help.&nbsp\\; Be safe
Old Jul 17, 2008 | 12:54 AM
Mighty MO's Avatar
Mighty MO
Default RE: REAR SHOCK PUMP PROBLEM
Dax, when you get no reading, do you try to pump it to get pressure up?&nbsp\\; Let all the air out manually then try pumping.
RidemyEVO
Jun 16, 2016 09:47 AM
k-hook
Feb 8, 2011 08:55 PM
Dax4800
Apr 25, 2009 11:16 AM
Dax4800
Jun 29, 2007 04:48 PM
kingultra
Oct 8, 2006 02:29 AM
