@#!@%$ Ignition Switch
Old Mar 15, 2006 | 10:48 PM
Fat John's Avatar
Fat John
4th Gear
Default @#!@%$ Ignition Switch
I'm trying to do some work on the fairing on my 2002 'Glide Classic, which requires total disassembly. I've got everything apart EXCEPT for the small plastic panel that surrounds the ignition switch. I need to remove the switch "****" from the ignition switch/lock, so I can slide the plastic panel off. I have almost completely disassembled the switch, found and removed the little allen screw under the little aluminum decorative panel, mashed on the little spring-loaded tab under the ****, twisted, turned, shoved, lit candles, burned incense, EVERYTHING, and I CAN'T get the **** off. I know I'm a complete doofus and must be missing something obvious, but the dremel's coming out soon and I'm gonna just cut the damn panel off!
Does anybody know the secret spell to get that @#^!*# **** off??????? Any help would be extremely appreciated and will save the life on an innocent trim panel.
Old Mar 15, 2006 | 11:17 PM
Bryan TTM's Avatar
Bryan TTM
Default RE: @#!@%$ Ignition Switch
are ya holdin yer mouth right ... makin faces ... hollered at the wife, kids, & dog ... til ya do ... aint comin off [:@]
Old Mar 15, 2006 | 11:36 PM
lil_gmac2's Avatar
lil_gmac2
Try the DIY section
Old Mar 15, 2006 | 11:48 PM
zubaugh's Avatar
zubaugh
PM me with your email and I can send you a pdf from the manual
Old Mar 15, 2006 | 11:57 PM
zubaugh's Avatar
zubaugh
Well you found the release button so maybe this will help:
To remove the ignition switch ****, insert the Ignition Switch key and turn to the UNLOCK position. Leaving the key installed, rotate the **** to ACCESS. Depressing the release button at bottom (left side) with a small screwdriver, push key down and turn an additional 60 degrees in a counter-clockwise direction. Lift and remove ****.
Old Mar 16, 2006 | 12:47 AM
Fat John's Avatar
Fat John
4th Gear
THANKS, guys, got it with your help. Normally, I'd search the crap of a forum before asking questions, but I'd spent all day with this thing (get mad, drink beer, repeat!) and I was really gonna just cut it off (the trim panel, that is).
Anyway, thanks again, and I'm impressed with the speed and accuracy of replies. I think I'm gonna like this place.
FJ
Old Mar 23, 2007 | 07:48 PM
beemer737's Avatar
beemer737
One addition that is critical and time saving, you rotate the key back left 60 degrees after depressing the release button..., NOT the ****.... You'll be there for hours otherwise...
motorcycleboy
2014-2024 Touring Models
May 11, 2014 11:56 AM
bearammus
Mar 6, 2014 08:08 PM
cmeans
EVO
Jun 13, 2011 10:36 PM
gordy1
Feb 10, 2008 05:43 AM
SparkyRKM
Aug 29, 2007 12:42 PM
