Zumo 550 Install
Old Aug 11, 2008 | 07:08 PM
Professor's Avatar
Professor
I hardwired mine to the side of the headlight that is set up for the european models. It's unused on the US models. It was an easy connection and I routed the plug through the throttle and idle cables hole to connect to the mount on my handlebars.
Old Jul 12, 2010 | 12:36 PM
SeaDragon's Avatar
SeaDragon
1st Gear
Default Installing Zumo 550 on 2010 / Ultra
Not sure if I understand, but figured someone could clarify. Using the plugged in headset, and having the GPS plugged into the AUX, you won't get the radio.
If so, anyone have a neat (inexpensive) solution?
Old Jul 14, 2010 | 01:57 AM
mike5511's Avatar
mike5511
So is this power connection using the un-used head light wires hot all the time, or only when the key is on??? Seems to me you would want the gps to stay powered up all the time.
My gps has a battery, so I guess it doesn't matter if it has power all the time or not, but using it in the car with a cig plug, it always has power so I figured that is the best way to run it on the bike.
Old Jul 14, 2010 | 05:13 AM
Jinks's Avatar
Jinks
On your bike both the wire behind the headlight & the cig lighter are switched with the ignition. In fact they are common on the same circuit. The Zumo comes on with the ignition, & turns off with the ignition. Of course it will continue to run on it's internal battery if you choose, or you can just leave the ignition on even if the bike is not running.
Old Jul 14, 2010 | 12:20 PM
mike5511's Avatar
mike5511
Thinking about this; if you want your gps powered all the time, it would probably be best to power it by plugging into the batt. tender plug. Anybody see a downside to this??
Old Jul 15, 2010 | 11:19 PM
Da Butcher's Avatar
Da Butcher
Subscribe. Because I simply forgot to on the last Zumo posts!
Talldog
Jul 12, 2015 10:19 AM
Dogdaz
27
Oct 4, 2012 06:54 PM
Kaz800
Feb 29, 2012 08:50 PM
06Roadie
Sep 9, 2008 04:16 PM
BlkNyt
Mar 20, 2007 10:13 PM
