Stereo Update Warning
Old Sep 2, 2009 | 07:51 AM
  #41
sgdiesel's Avatar
sgdiesel
Originally Posted by iclick
It updates the firmware on the HK head unit. I've done it about five times, going back and forth and finally settling on 8.19 (latest), and never had a problem. I wasn't aware that CD's came in different thicknesses, and that's a new one on me. I use very old CD-RW 4x.
From memory I believe the rewritable CD's are slightly thicker, these are the type that can be burnt a number of times, but only on a compatible CD writer - I think HP were in to it
Old Sep 2, 2009 | 08:46 AM
  #42
hawg08's Avatar
hawg08
Originally Posted by Tinkermc
my radio seems to work well but many times I hear people doing update having troubles. I think since mine ain't broke I won't fix it.
I concur!!!!!!!!!!!
Old Sep 2, 2009 | 08:55 AM
  #43
driven2fish's Avatar
driven2fish
Originally Posted by hoosierhog88
I took a look at the HD site. The following is in the directions...
The radio will automatically update the software. This process will take about seven minutes. A message will inform you of the progress of the update. The radio will power down and restart automatically twice during the update. If the CD appears jammed or will not eject, turn off the radio, turn the ignition key switch to OFF, pull the vehicle maxi-fuse, and wait five minutes before replacing the fuse. Try ejecting the CD again once power has been restored.
I have an 06 SG and did the update. I read if it gets stuck to pull the maxi-fuse. I always have bad luck and since they put that in there I knew I would have to do it. CD would not come out and I did the fuse thing and waalaaaa it came out.
good luck
Old Sep 2, 2009 | 09:27 AM
  #44
Hawnted's Avatar
Hawnted
good luck
There is a newer ST10 update that comes with the new headsets. It is a VOX update. ST10v8.21.0 is latest. TM320v8.19 is still the latest for audio though. The 8.21 VOX update is not on the HK site as of yet, a CD came with my headset.
Old Sep 2, 2009 | 01:28 PM
  #45
timvan's Avatar
timvan
pull the fairing, radio and open it up... not that big of a deal. release the carrage and it should come out... you may have to manually turn the eject motor
Old Sep 2, 2009 | 01:32 PM
  #46
Our07Ultra's Avatar
Our07Ultra
Loose a minute a week ooohhhh!! Who uses the clock anyway???
Old Sep 2, 2009 | 02:54 PM
  #47
Super Mario's Avatar
Super Mario
If it ain't broke, don't fix it !!! Don't you guys ever learn?
Old Sep 2, 2009 | 03:19 PM
  #48
Sharknose's Avatar
Sharknose
Early on the updates made a real difference. One of the first ones gave a very noticeable increase in volume.
Old Sep 2, 2009 | 03:29 PM
  #49
cbears's Avatar
cbears
Mine seems fine, think I'll leave it be.
Old Sep 2, 2009 | 04:01 PM
  #50
swomack's Avatar
swomack
8.19 came out in March of 2007 so if your bike is newer than that you're wasting your time.
