MP3 CD's?
Old Aug 17, 2008 | 08:03 AM
shekmark's Avatar
shekmark
Default MP3 CD's?
In a previous thread some guys talked about music CD's that held a couple hundred songs. What is the type of CD? Is it a technique for downloadind? Thanks
Old Aug 17, 2008 | 08:14 AM
badlandr's Avatar
badlandr
I got 144 songs on just a regular data CD burn nothing special.
You can get more by setting your mp3 rate to 128kps. I use 193kps on mine I really don't think for playing on the bike you'd notice a difference. BTW you can use Windows Media player to RIP and burn your cd.
Old Aug 17, 2008 | 08:16 AM
Wassup8687's Avatar
Wassup8687
Media Monkey works very well to convert songs to the MP3 format.
Old Aug 17, 2008 | 08:24 AM
natewat's Avatar
natewat
The H/K Advanced Radio can play CDs with songs burned on them in the *.mp3 format (ie: freebird.mp3). These are songs just like an MP3 player would store, read, and play. If you have the right software in your PC you can burn your tunes on to a CD-R in *.mp3 format and play them on your bike. Although the audio quality will be less than a standard CD type song, on your bike going down the road you probably won't notice it. And you can often get hundreds of tunes on one CD.
I think I have the tunes from 12 CDs on one MP3 disk in my CD player now. I selected Random Play and I rarely hear the same song, even on long rides.
Hope this helps! Take Care!
Old Aug 17, 2008 | 08:36 AM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
I too thought it was some special CD. It's just the format you record to the CD
Old Aug 17, 2008 | 08:47 AM
Fahpah's Avatar
Fahpah
If riding more than just to/from work I really prefer CDs with MP3 Formatted songs.
Most of the CDs I have made hold a little over 110 songs, varies with the length of the songs of course. I may also be using a slightly higher resolution on the cds I make, hence the fewer number of songs on one CD.
I really dont try to pack as many songs on a CD as possible, 110 songs is somwhere in the neighborhood of 6 hours of music without repeats and I cant ride that long before I gotta get gas anyway, so I just change CDs when I fill up.
Old Aug 17, 2008 | 08:57 AM
Wecroft's Avatar
Wecroft
The one point being missed is that you have to burn the CD as a "Data" disc and not a "music" disc or you'll only end up with a disc that holds about 12 songs.
Old Aug 17, 2008 | 10:43 AM
iclick's Avatar
iclick
MP3's are stored as files on a CD just like you would have them on your computer, and you can even separate them into folders and sub-folders if you wish. Once on the CD you can insert them in your HK head unit and they will play. The advantages are that you can get more the 200 songs on one CD, and the CD player does not track the songs as it does with normal CD's, so there is less chance of skipping or other interruptions. It stores segments of the file in memory and plays it back. I have one CD with 229 songs, and all are recorded as 128kbs/44khz. If you save the MP3 files at a lower quality like 96kbs you could store even more on the CD and wouldn't likely be noticeable.
If you have a collection of MP3's you can simply copy/burn these over to a CD-R without special software. OTOH, to rip a CD to MP3 you'll need to use software like Nero or Windows Media Player.
Old Aug 17, 2008 | 02:14 PM
scoteh's Avatar
scoteh
I use ITunes for my storage and burning. I use the highest quality MP3 settings and get anywhere from 100-125 songs, depending on song length. My library is at about 1225 songs, all of which I really like. I pay attention to the number of MB's I'm taking up as I make them. Anything over 696 MB's gets dicey. Also, each disc has its own folder so it's always easy to make copies.
Old Aug 17, 2008 | 02:17 PM
omgtkk's Avatar
omgtkk
Has anyone had any luck organizing your MP3's into folders before burning them onto CD. Another member reported doing it successfully, but he never responded as to what software he used or how he did it. I would like to put individual albums into folders so I can sort through them and play them when I want. Other members reported that the HK stereo didn't recognize the folders.
