How do I connect HD Men's Heated Gloves?
Old Aug 22, 2008 | 02:47 PM
Johan96's Avatar
Johan96
Lightbulb How do I connect HD Men's Heated Gloves?
Hi Folks
Can anyone please tell me how I connect these gloves? Is i possible to use the cigarette lighter on the street glide? THX! Any pros or cons on these gloves?
http://*******.com/3iv6h [www_harley-davidson_com]
Old Aug 22, 2008 | 09:40 PM
Cruise's Avatar
Cruise
HD gloves are made by Gerbing. Actually I have the Gerbing brand of gloves, jacket liners (2) and thermostat. I did buy an extra HD thermostat for the wife's liner though. The gloves as well as every Gerbing article comes with a wiring pigtail...(a wiring harness that connects directly to the battery with a connection point for the connectors on any item to plug into.) The gloves also come with "Y" wiring so that one end plugs with each glove with the Y part and the single end then connects to the battery pig tail connection point were ever you have located it. I never use the gloves alone like this since if it is cold enough for gloves I wear my jacket liner too. That way I plug my jacket to the pig tail connection and the gloves plug into the connections at the end of the sleeves on the jacket liner. It makes for no wires hanging around loose like the glove's Y connection would. That is a simple non thermostat hook up. But of course I have the thermostat which means my jacket plugs into it and it into the pig tail. If I had the pants, the pants would also plug into the jacket liner, socks into the pants for a complete system. It's hard for me to explain all this but I hope you get the drift of the connections. I would suppose HD gloves come with the same wiring Y and pig tail that the Gerbings did with mine.
Old Aug 22, 2008 | 11:13 PM
gman's Avatar
gman
got my controller and cables from warmandsafe.com. much cheaper and work well.
Old Aug 23, 2008 | 12:07 AM
tmblweed's Avatar
tmblweed
Buy the "Y" connector, run one wire down each sleeve so it hangs out about 3 or 4 inches with the other end hanging out at the jackets waist. ( I run mine under the zip out lining ) Run your battery connector from the battery under the seat and hang it out the left side. When you get on the bike plug the the two together and then plug up the gloves. A thermostat can be connected as the gloves can get quite hot. You may need to ask the parts people for a female connector to modify the battery tender male end that HD puts on some bikes. Good luck, its not as hard as it sounds.
Old Aug 23, 2008 | 07:30 AM
Johan96's Avatar
Johan96
Thanks for all the answers! Think I will order a pair. Can be quite cold here in Norway!
Old Aug 23, 2008 | 07:51 PM
bigskyhd's Avatar
bigskyhd
Too bad it's not nice and warm year round like it is here in Montana. Love that heated gear.....
Old Aug 25, 2008 | 05:50 AM
Johan96's Avatar
Johan96
Talking
Hate to freeze
Old Aug 25, 2008 | 07:03 AM
Dennydp's Avatar
Dennydp
Ive had the Gerbing gear since 96,works great!
Old Aug 25, 2008 | 07:51 AM
Cruise's Avatar
Cruise
Just on a side note to the question about the cig. lighter connection.... On Gerbings site under accessories you can order the adapter to connect any of their heated gear to the cigarette lighter.
http://www.gerbing.com/Products/accessories.html
ROCKOUT Rocker Products
Dec 2, 2015 03:40 PM
dyna-rider
Oct 30, 2010 05:26 PM
firedocs
Dec 28, 2009 09:15 PM
johnkn
Nov 21, 2008 07:51 AM
Domestic Violence
Oct 25, 2006 01:25 AM
