rear fork pivot shaft
Old Aug 23, 2008 | 10:56 AM
acamj's Avatar
acamj
Default rear fork pivot shaft
Does anyone know the torque spec on the rear fork pivot shaft nuts? Im trying to troubleshoot a vibration problem on an 07 street glide and my manual isnt in yet, also do you have to remove the pass pegs for access or do you just pop off the crome plugs? Thanks Mike
Old Aug 23, 2008 | 01:37 PM
skooba's Avatar
skooba
I beleive they are 50lbs. I believe you need to remove the pegs and the plugs. But if you can fit the socket and the wrenchhead in there without removing the pegs go for it.
Old Aug 23, 2008 | 05:30 PM
hitone's Avatar
hitone
I just read an article where they replaced the stock shaft with an upgraded aftermarket set up to eliminate "bagger wobble" and they recommended tightening to 40 ft lbs for the first while and then retightening to 50 ft lbs after a few miles. No expalnation was given.
Old Aug 23, 2008 | 07:13 PM
acamj's Avatar
acamj
Thanks for the info ill check it in the morning
Pigbacon
Aug 30, 2015 10:45 AM
dawg
Feb 28, 2012 01:26 PM
Bill420247
Dec 28, 2007 11:58 AM
Kolni
Jul 24, 2007 08:53 PM
glideridemike
Mar 9, 2007 10:31 PM
