Glide-Pro or True-Track
Old Aug 26, 2008 | 11:17 PM
mchacon's Avatar
mchacon
Default Glide-Pro or True-Track
Swingarm stabilizer or swing arm pivot anchor or both?
I've been reading about the different options to prevent wobble (Which I have not experienced at any speed)
What is the benefit of one type over another. I know there are several brands but they seem to fall under the two categories.
What about both for extra insurance? Overkill?
Old Aug 27, 2008 | 08:27 AM
Skulmn's Avatar
Skulmn
Look at the "Bagger Brace" seems to be the new most popular.
Seems well made and easy to install. If I do it, I will be going with the Bagger Brace.
Also, seems to be the least expensive.
Old Aug 27, 2008 | 10:56 AM
bagman1's Avatar
bagman1
What about the swing arm pivot kits? I see glide pro has the shaft and outer bushings, but I saw another type somewhere that show a new delrin or metal bushing in the swing arm housing itself in addition. If oem s/a bushings are rubber that seems like it would defeat the purpose of the glide pro swap.
Im thinking of doing the bagger brace and a swing arm pivot set together, but want to find a good s/a kit.
Old Aug 27, 2008 | 04:01 PM
pittguy's Avatar
pittguy
Not sure of your bikes mileage but replacing the swingarm bushings may tighten your bike up.Doing so at time of kit installation-whichever you go with-wopuld give ultimate results. The harder aftermarket bushings have been known to increase vibs-your call.Checking bikes alignment along with motor mounts is advised.Neck brgs are often overlooked.
Old Aug 27, 2008 | 04:38 PM
gliderman's Avatar
gliderman
I'm selling a pair of Sta-Bo bushings. Excellent condition, like new. $50 includes shipping. In case you want to give them a try?
Old Aug 27, 2008 | 04:43 PM
TC113's Avatar
TC113
6th Gear
What year and model do they fit?
Old Aug 27, 2008 | 05:31 PM
rdkingryder69's Avatar
rdkingryder69
The guy that does my work recommended the ride straighter(not the right name) because it has two mounting points and that is what he has on his. First thing I noticed was it takes bumps better. I haven't had the chance to really push it yet but once you feel the death wobble you will wish you spent the cash. Trust me.
Old Aug 27, 2008 | 05:36 PM
UltraKla$$ic's Avatar
UltraKla$$ic
You may want to consider the Bagger Brace rear stabilizer as Skulmn has stated.
Call Ron or Stacey at 1-480-967-7588.
$289 w/free shipping
Old Aug 27, 2008 | 08:06 PM
Egldr05's Avatar
Egldr05
I didn't think I had either until I put the Bagger Brace on. A completely different handling motorcycle.
Rick
Old Aug 28, 2008 | 05:23 AM
RjCapp's Avatar
RjCapp
From what I have read they all work well.
