wrong Primary oil
Old Sep 3, 2008 | 01:23 AM
DOGCOP's Avatar
DOGCOP
Default wrong Primary oil
i think i may have screwed up, i changed my fluids today, mobil 1 20/50 in engine, red line in transmission and amsoil 75/90 in primary. now i read that the primary should have (maybe mobil 20/50 or other oil like that) please help me asap i need to know if i have to get this amsoil out quickly. i'm leaving on a big trip wed sept 10. thanks for the input
Old Sep 3, 2008 | 01:28 AM
FLHXn's Avatar
FLHXn
I seriously doubt it will hurt it any but,,,, It should be a lighter weight motor oil. I use bulk 5w30 oil that I get at work. I've been told that it's better to use a non synthetic oil in the primary. It's really just a chain in there... I'd change it since it is soo easy. Just get a quart of cheap-o 10w30 or something like that.
Old Sep 3, 2008 | 01:39 AM
AustinRider's Avatar
AustinRider
I doubt if it will hurt anything, but I just don't like AmsOil products. I used to use it in my '04 F150 and had to rebuild the engine after 60,000 miles. I believed what they said about going 25,000 miles between oil changes. It is pure BS and I don't know how they continue to get away with that.
I'm using Redline products. I've never heard that its bad to put synthetics in the primary. I used the Redline MTL and so far I really like it.
I wouldn't run out and get another product to change the primary fluid right now since you just changed it. But when it comes time for your next oil change I'd recomend something other than AmsOil. That's just my honest opinion.
Good Luck and Good Riding...
Old Sep 3, 2008 | 01:44 AM
DOGCOP's Avatar
DOGCOP
Default SORRY for dumb questions but
in the primary is our clutch correct? and if it is do they call that a wet clutch?
Old Sep 3, 2008 | 01:46 AM
bagman1's Avatar
bagman1
Wrong, There is also clutch discs in there too! This is where the damage will occur first. Yes to the wet clutch.
Old Sep 3, 2008 | 01:47 AM
dawg's Avatar
dawg
Yes, yes
Old Sep 3, 2008 | 01:58 AM
DOGCOP's Avatar
DOGCOP
Default clutch
so the amsoil will not harm the clutch or make them slip? sorry for all the dum questions but this is all new to me. thanks again for the fast replys
Old Sep 3, 2008 | 02:04 AM
sifularson's Avatar
sifularson
What model and year do you ride?
Anyway . . . one of these might help.
http://search.ebay.com/search/search...ual&category0=
Old Sep 3, 2008 | 02:15 AM
DOGCOP's Avatar
DOGCOP
Default manual
i did buy the manual today, 08 ultra classic, i thought i had done my homework on the oil thing but then i read somewhere that the 75/90 amsoil may cause the clutch to slip that is why i was questioning. like i sai d sorry for all the dumb questions just don't want to get on the road and have the clutch start slipping. i really do appreciate all the replys. thanks again
Old Sep 3, 2008 | 02:22 AM
sifularson's Avatar
sifularson
My opinion is that the gear oil you used may cause some problems with the clutch slipping. I would ride it and get it hot and drain it and replace it with the correct oil. I was using HD formula 1 until recently I went to Redline primary oil. JMO
Steve
