Fairing Problem
Old Sep 10, 2008 | 06:36 AM
mariner227's Avatar
mariner227
Default Fairing Problem
I was riding yesterday and noticed that the windshield had tilted back towards me. I stopped and realized that the three metal inserts had pulled out of the fairing. The inserts are the ones that the three torx screws that hold the windshield in place are screwed into. I use a taller than stock windshield and I'm sure that it puts way more pressure on these inserts at 75 mph.
Has anyone else had this problem? I'm thinking of using some epoxy glue to hold the inserts in place. Any ideas would be appreciated. The warranty expired last month on my 07 ultra.
Old Sep 10, 2008 | 06:45 AM
Bail's Avatar
Bail
You are right on track.....epoxy them in. Mine are holding so far. If you change you shield often, each time you tighten them the inserts are pulled a little. A really good 2-part epoxy has held mine so far and I change shields for spring/summer/fall. Good luck!
Old Sep 10, 2008 | 06:56 AM
mariner227's Avatar
mariner227
Thanks! I also switch windshields often.
Old Sep 10, 2008 | 07:10 AM
gs34doc's Avatar
gs34doc
Big Kahuna HDF Member
Here's the part number for the threaded inserts ....16585-06....these just screw into the fairing to replace the one that's pulled out. Couple of bucks at the dealer.
Old Sep 10, 2008 | 09:49 AM
pappy's Avatar
pappy
If you use epoxy just put a little on the outside threads then screw it in
the fairing. If you put it in the fairing first it will push to the inside threads
and then you will be screwed.
Old Sep 11, 2008 | 10:33 AM
mariner227's Avatar
mariner227
Thanks for the information! I called around and the third dealer I talked to had them in stock. Easy fix! The part number is 16585-96 for anyone else that needs them. Again the members on this forum have saved me time and $$$.
Old Sep 11, 2008 | 11:15 AM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
Never heard of that problem before.
Thanks for the information.
fishbust
Jun 4, 2017 08:14 AM
Candubrain
May 28, 2017 07:12 PM
load97
2014-2024 Touring Models
29
May 11, 2014 07:33 AM
Rock Chalk
Apr 2, 2014 01:08 PM
trackadaptor
Jul 17, 2013 01:35 PM
