Winter Battery Storage
Old Sep 11, 2008 | 10:04 AM
hyfly1's Avatar
hyfly1
Default Winter Battery Storage
I have a 2008 Road King with factory security. My garage does not have electricity, so leaving the battery on a trickle charger in the garage all winter is not an option. If I take the battery off the bike for the winter what happens to the security system? Do I have to get the dealer to re-set it in the Spring?
Old Sep 11, 2008 | 10:08 AM
BikerGent's Avatar
BikerGent
check with your dealer ,just a phone call away !
Old Sep 11, 2008 | 10:14 AM
Windup08's Avatar
Windup08
No you shouldn't have to have the dealer do anything. Just put the battery back in. If you also have a pager you might have to re-mate the pager to your bike, but that would be all. I don't think your security system will keep working without the battery, but if that isn't a concern just pull the battery.....give it a good charge before you put it back in next spring.
Old Sep 11, 2008 | 12:04 PM
hoz88's Avatar
hoz88
Park it in the living roon - you have electricity in there dontcha????
Old Sep 11, 2008 | 12:43 PM
ssihogdog's Avatar
ssihogdog
If I remember correctly -- and I am sure someone will correct me if I don't -- before disconnecting the battery - disarm the security system by turning on ignition with fob nearby, pull the maxifuse, then remove the battery. Reverse in spring. It must really S$ck having to deal with winter...
Old Sep 11, 2008 | 03:51 PM
007 ultra's Avatar
007 ultra
Extension cords are not very expensive unless your garage is a half mile away from your house or power source.
A couple days on the trickle charger once or twice over the winter should do it as long as you have a good, servicable battery to start with.
Old Sep 11, 2008 | 04:26 PM
nocarb's Avatar
nocarb
I would pull battery and store in a warm spot. Charge a couple times during winter and before you reinstall.
Old Sep 11, 2008 | 05:26 PM
HDUltraRider's Avatar
HDUltraRider
Keep it in the Bike and ride when every you get a chance
Old Sep 11, 2008 | 05:33 PM
neohiobiker's Avatar
neohiobiker
I vote for the extention cord
Old Sep 11, 2008 | 05:34 PM
QWeeks's Avatar
QWeeks
they have sun powered chargers at the auto stores.might look into that.
