High idle - again
Old Sep 16, 2008 | 07:11 PM
Chula's Avatar
Chula
Does anyone know if the 09s have this problem?
Old May 15, 2009 | 08:45 PM
phattey's Avatar
phattey
Well I just had this problem occur tonight. Fired the bike up and it immediately was idling at 2k. It's never done that and I've had it since Oct '08. Once it warmed up the idle did settle down a little to 1200-1250 so I rode some. Every time I stopped the idle was 1200-1250. It used to be around 950-1000. Hmmm...
When I finally got home and pulled in the garage I let it sit a bit and it settled back down to 1000. I'll see in the morning and if it does it I'll try the reset technique mentioned all over this site.
I will ask my dealer too.
Old May 15, 2009 | 09:02 PM
flyslow's Avatar
flyslow
Get a Master tune TTS and a dynotune. Once I did that I never had idle issues again and the bike runs alot stronger.
Old May 15, 2009 | 09:38 PM
fathertime's Avatar
fathertime
From: CHILLIWACK B.C CANADA: have a u.s shipping adress
Originally Posted by Toe Knee
I had this issue with my 08 EGS..The second night i had the bike...I could clear it but then it would go RIGHT back to high idle with no throttle response.
It turns out the connector under my seat was 1) not clamped down at the factory and 2) the pins in the connector where damaged.
It was inspected, repaired and reconnected. I used some duck tape to make sure that the little pooper doesn't disconnect again and have beat the crap....ah, ridden the bike for about 850 miles with out a hick up.
BTW-this is a very common reason why the "system" goes haywire. The connector under your seat. (from what I've read) SEVERAL bikes at my dealer had many hours of time in them before they realized that the factory just wasn't paying good enough attention to the somewhat delicate connector.
I say disconnect, inspect and SECURELY reconnect that connector.
BTW---H-D isn't the only player that stupid little connectors can be a problem.
please take a pic of the area under the seat and point out the problem connector..i cant see anything out of the ordinary?
Old May 16, 2009 | 08:12 AM
8post96's Avatar
8post96
Ahhh!!! The simplicity of a carb and cables!!!!!!!!!!!
Old May 16, 2009 | 10:08 AM
DrPlastic's Avatar
DrPlastic
Mine did this until the dealer reflashed the ecu after I did my 1000 mile service. It hasn't happened since. One thing I noticed was if you shut the bike off right after revving the engine it remembers the last idle setting and reverts to that on start up. Again after the patch was applied I have not had that problem again.
Old May 16, 2009 | 05:58 PM
K00LJerk's Avatar
K00LJerk
I think its more of an "educate" problem when HD sells a bike they should inform buyers to make sure the idle returns before hitting the kill switch
Old May 16, 2009 | 06:12 PM
myred55's Avatar
myred55
I have an 09 and it happened to me once in 5K miles. Not a big deal to me.
Attached Thumbnails High idle - again-rkonbike.jpg   High idle - again-55chevy.jpg
Old May 16, 2009 | 06:43 PM
Norm's Avatar
Norm
Same with that damn electric starter. Bring back the old simple kick starter.
iclick
Jul 15, 2022 05:30 PM
pmblackhawk
Feb 23, 2014 05:19 PM
river_rat
May 23, 2011 09:19 PM
bill1nat
May 9, 2010 10:23 PM
ezriderpgh
Dec 28, 2008 10:13 AM
