HID headlamps
Old Mar 26, 2006 | 06:03 PM
trning's Avatar
trning
Default HID headlamps
I have an 05 Electra Glide Classic. What is required to convert to HID headlights. How hard is it and what does it cost.
Thanks in advance.
Old Mar 26, 2006 | 06:41 PM
bountyhunter's Avatar
bountyhunter
Default RE: HID headlamps
Part 68094-06, complete HID dual bulb kit. Should get it for at least 20% off list, about $420.
Old Mar 26, 2006 | 07:01 PM
05 Ultra's Avatar
05 Ultra
I have the dual light setup kinda like the Mocos HID light so I decided to try out one of the HID conversion kits out there. I'll have to let ya know how it works out as I just ordered it Friday. Looks like a snap to install and a whole lot better then just putting in a xenon type bulb that could burn out in a month. I did a search on them in a few different forums and couldn't come up with any info good or bad so i figured someone has to be the guinea pig.
Old Mar 26, 2006 | 08:12 PM
Ram's Avatar
Ram
I have installed the H-D, HID headlamp kit on my RK. I love it and it works great!
I'm kind of a stickler for light and noise. Also just bought the passing lamps which have replace-able H-3 lamps in the reflector assy. Upgraded the stocker 35watts to the Sylviania SilverStars at 55watts each. Man what a difference that makes as well.
Only thing just besure that parts guy gets your HID for your EG, not for a RK! Makes a difference, install wise. Not over all HID. RK is not going to install right on EG and vice versa!
Old Mar 26, 2006 | 08:44 PM
zubaugh's Avatar
zubaugh
Harley is discontinuing the HID according to my stealer. Apparently there were not enough of us paying $500 for the light. Get one while you can.
As for the install, according to the instructions you'll need to pull the outer fairing, gas tank and pop a pin on a connector. You should have a Service Manual to help identify the connectors (ignition and right hand controls). I found it pretty easy since I had my fairings and tank off for painting.
Old Mar 26, 2006 | 08:59 PM
CHEYENNE's Avatar
CHEYENNE
HD and Kurkyan make a HID setup.
I will be going HID soon after I come up with the extra cash, still wanna get the progressive 440's also... Someone wanna buy em for me?!?!?!
brianb21
Mar 15, 2012 08:45 PM
09sporty
Jul 12, 2011 07:01 PM
zukeeper
Mar 16, 2007 09:41 PM
lawdogso
May 16, 2006 11:00 PM
05 Ultra
Product Reviews
Apr 25, 2006 12:35 AM
