07-08 Wheels
Old Sep 26, 2008 | 11:20 AM
Egldr05's Avatar
Egldr05
Default 07-08 Wheels
Can anyone tell me if there is any difference between 08 wheels and 07's other than bearing size? I need to pick up a laced rear wheel for a RK swingarm conversion.
Thanks,
Rick
Old Sep 26, 2008 | 12:22 PM
Tinkermc's Avatar
Tinkermc
I thought both had the 1" axle and the spacers could be diff.
Old Sep 26, 2008 | 01:37 PM
GlennA's Avatar
GlennA
If you look in the catalog, you order your wheel then order the bearing kit to fit by application. That makes me believe the wheel is the same, just different bearings. Hopefully my deduction is correct since I have a set of 08 SG wheels that I plan to put on my 07RK.
Old Sep 26, 2008 | 05:29 PM
jag1886's Avatar
jag1886
The wheels are the same you just need the proper bearings and inner spacers between the bearings.
Old Sep 26, 2008 | 05:33 PM
blueflht's Avatar
blueflht
there may be an issue with the thickness of the bearings. 07 with 1" axle is wider in the race than the 25mm bearing of the o8. this can affect bearing runout and spacer placement
Old Sep 26, 2008 | 05:43 PM
Zimbob's Avatar
Zimbob
The only difference is the bearings, I know, I changed my '07 laced wheels to a set of '08 cast wheels.
Old Sep 26, 2008 | 06:13 PM
Egldr05's Avatar
Egldr05
You wouldn't happen to have a rear laced for sale would you?
Rick
squirrelslayer
Wheels/Tires
Mar 4, 2013 02:48 PM
Shrug
Wheels/Tires
Feb 14, 2013 08:02 PM
Tanker2
Mar 28, 2011 04:48 PM
Sincecrazy
Jan 5, 2011 06:31 PM
fathertime
Sep 22, 2008 08:07 AM
